Batteries
Our team did a 16 amp battery test. A 2005 battery went down to 10 volts in 21 minutes. The other batteries we tested took at least 40 minutes. One of our 2005 batteries is of poor quality.
Re: Batteries
Re: Batteries
Re: Batteries
I'm a little confused. That does not look like an Exide-18-12 official FIRST approved (re: only Brand and Model number battery you can use in 2005) in your picture.
Explanation? |
Re: Batteries
Re: Batteries
Sorry about that.. Didn't mean anything by it. Forgive me? ![]() |
#7
Re: Batteries
yea. Someone said to switch batteries but we took the pic anyway.
#8
Re: Batteries
If anyone is curious what we did to test them - we built a circuit that had a load on it and was connected to the battery (and two large muffin fans to cool it all off) then timed how long it took the battery to drop to 10v.
#9
Re: Batteries
It looks like you used some sort of large resistor. In that case, you were not drawing exactly 16 amps the whole time. Because you only measured down to 10V, it is probably close enough, but I just wanted to point it out.
#10
Re: Batteries
Yeah it was a resister, not sure what its rating was though. Why wouldn't it be pulling 16 amps all the time though?
And we actually timed it a little past 10v, but the only time amount we cared for was 10v. [Edit: Hmm...I didn't really mean to make it sound "snappy", I just don't understand why it wouldn't do that.] Last edited by DarkJedi613 : 05-02-2005 at 23:43. |
#11
Re: Batteries
V=IR. If V goes down, and R is constant, I must go down.
#12
Re: Batteries
Re: Batteries
It is interesting to note here that an 18 AH battery cannot supply 18 amps for one hour. The spec sheet lists the test parameters and the final test voltage vs. time but it should be noted that the battery changes output with temperature as well. |
#14
Re: Batteries
Re: Batteries
The capacity of the EX-18 batteries does appear to be 50% lower. If your robot will have high current draw you need to pay careful attention to this issue... |
| Keeping batteries during shipping | Andy Brockway | Rules/Strategy | 4 | 17-02-2005 17:37 |
| # of Batteries at regional | HPA_Robotics_13 | Electrical | 15 | 15-02-2005 23:18 |
| EX18-12 Batteries in KOP | Andy Brockway | Electrical | 3 | 14-01-2005 11:34 |
| Batteries Exide 2005 Quanity | Mike Martus | Electrical | 6 | 13-01-2005 19:44 |
| HELP - We have no batteries!! | Rick Gibbs | Championship Event | 3 | 24-04-2002 19:07 |
