Go to Post You are not limited by your resources, but by your imagination. - John Gutmann [more]
Unread 05-02-2005, 18:45
gemccnp gemccnp is offline
gemccnp is an unknown quantity at this point
Best Way To Insert Autonomous Code Into Default then load help.? :-)?
Hello Robot Gurus, I am not as experienced in C as I should be but am trying to help out our team.
I know I have good default code but I am wanting to add autonomous code in the right places. I have found some good documents. I know there is one main file. Does anyone have any links or docs on how to do this. Which file do I edit ? Do I edit one file and then recompile the frc default ?
It looks like I need to add a file called auto.h to the rest of them, is this true? The camera.c file with the default code seems adequate but is it just for controls?
Thanks for any help and links.
Sincerely
George Murphy
Team #1696
Unread 05-02-2005, 18:51
probizzle's Avatar
probizzle probizzle is offline
AKA: Prabhas Pokharel
#0639 (Code Red)
probizzle will become famous soon enoughprobizzle will become famous soon enough
Send a message via AIM to probizzle
Re: Best Way To Insert Autonomous Code Into Default then load help.? :-)?
The place for adding autonomous code is in User_Autonomous() in user_routines_fast.c, under the comment
/* Add your own autonomous code here */
It will be a good idea to make an auto.h/auto.c to have all your autonomous functions, and use user_routines_fast.c to call a central function (auto_main() perhaps).
Anyway, look at http://kevin.org/frc for lot's of more cool information.
[edit] Also, look at http://www.ifirobotics.com/docs/lega...2-apr-2004.pdf too. This is last year's programming reference guide. Most of hte things there still apply. Obviously though, you won't find any references to the camera there. (and don't bother about references to the line tracker, which was "last year's camera"). [/edit]
Code Red Team 639 Winners of the 2005 FingerLakes Regional with 191 and 494.
http://pset.deu83.com << my baby
http://www.setgame.com/set/ << it's mother
Unread 05-02-2005, 18:58
Thumbs up Re: Best Way To Insert Autonomous Code Into Default then load help.? :-)?
Thanks a ton for the quick response and great info. That clears up a lot for us!
Cheers!
Where to insert code Autonomous mode caderader Programming 5 18-02-2005 16:49
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
How long does it take you to load the default code? vegasmcse Robotics Education and Curriculum 10 03-11-2003 21:41
