Go to Post This isn't a science fair, sometimes it's okay to give away the answer, especially if they learned something on the way there. - Karthik [more]
Unread 08-02-2005, 00:21
chippermonky chippermonky is offline
chippermonky is an unknown quantity at this point
microswitches and other sensor question
Does anyone know where the manuals are for hooking up various sensors to the digital (and analog) inputs. I was under the impression that it was just a matter of shorting the white and the red wire, but that aparantly was not the case. Right now I am absolutely clueless on how to hook up a sensor even as simple as a microswitch and I would really appreciate some help. Alongside of the microswitches, could anyone tell me how the rotory sensor works (well, how to hook it up and get it to count anyways) and how to hook up the CMU cam. thanks in advance.
Unread 08-02-2005, 03:20
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: microswitches and other sensor question
Check here..
http://www.ifirobotics.com/docs/rc-r...01-31-2005.pdf
Page 9 says to says to use the Signal pin (white) and the Ground pin (black) for hooking up a switch to the digital inputs.
As for wiring analog sensors like potentiometers (rotary sensor?) refer to page 8 of the same manual.
Good Luck
Unread 08-02-2005, 03:31
Electrical Engineer
Rookie Year: 1995
The manual should be here but it looks like the link is broken. I have informed IFI of the problem and I would guess that you will be able to link soon via this page.
Meanwhile, a switch is connected between the signal and ground connections on the digital I/O pins.
Please search these fori for the words camera and encoder. There are numerous threads dedicated to these topics.
Mike Betts
As easy as 355/113...
Unread 08-02-2005, 09:30
That's the manual for last year's RC, which is here: http://www.ifirobotics.com/docs/lega...004-feb-19.pdf. The manual for this year's RC is here: http://www.ifirobotics.com/docs/rc-r...01-31-2005.pdf. Both are availible from the Robot Controller page, it's just the overview page that hasn't been updated.
