Go to Post After all, professional engineers know The Right Way To Do It (TM) and if we knew that we'd be deprived of the educational experience of screwing up. - phrontist [more]
Unread 08-02-2005, 22:13
skillinp's Avatar
skillinp skillinp is offline
FRC #1388 (Eagle Robotics)
skillinp is an unknown quantity at this point
Question "sandwich" claw
when building a claw, would it be beneficial to make it in a sandwich like fashion for example a layer of aluminum, a layer of fiber/plexi glass, then a layer of aluminum all bolted(or whatever it takes t attach them) together, to use the benefits of each part to the max?
thanks
There's no honorable way to kill, no gentle way to destroy. There is nothing good in war. Except its ending.
Abraham Lincoln
"The Savage Curtain"
Unread 08-02-2005, 22:41
Re: "sandwich" claw
Composite materials take many forms, and are used for (you guessed it) a lot of different purposes. My wife works on the F22 fighter. Most of the wing spars are RTM carbon fiber parts (don't worry -- this isn't classified), but every few spars one is replaced with titanium. Titanium is heavier and less stiff, but it resists certain kinds of battle damage better. The wing is a titanium/carbon fiber/resin composite structure. We asked about getting some QC rejected carbon fiber spars for our robot, but it turns out they belong to the Air Force, too.
Your specific suggestion for an aluminum/fiberglass sandwich makes me wonder what you are trying to do? If you want a superstrong, lightweight, very stiff structure, you would be better off making a laminate of 45/45 biaxial fiberglass epoxied to both sides of structural foam like Divinycell. The aluminum won't buy you much, and will bond poorly to the fiberglass. IMHO, using mechanical fasteners to create your composite panel is suboptimal. Most boats and a lot of airplanes are held together by glue, not screws.
Let us know what you want your structure to accomplish and maybe we can give you better suggestions. (I wanted to make an epoxy/carbon fiber/fiberglass arm for our 'bot, but I was outvoted by conservative teenagers. Oh well...)
Rick Tyler
Unread 08-02-2005, 22:49
J Flex 188's Avatar
J Flex 188 J Flex 188 is offline
"flock their sheep"
AKA: Jeffrey Li
FRC #2505 (The Electric Sheep) & FRC #0188 (Blizzard)
J Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond repute
Send a message via ICQ to J Flex 188 Send a message via AIM to J Flex 188
Re: "sandwich" claw
conservative teenagers?! only in robotics lets say.
Woburn Robotics, Class of 2005.
Unread 08-02-2005, 22:54
skillinp's Avatar
Re: "sandwich" claw
Rick Tyler
thats a lot of materials I've never heard of. is there somewhere i can go to find out more about them? by the by, this is for the claw on the end of a long arm, so I'm trying for light, stiff, and well i guess everything you listed there.
thnx
Abraham Lincoln
Unread 09-02-2005, 01:04
Re: "sandwich" claw
Check this Website:
Materials information. It's a site for amateur boatbuilders, but a lot of the materials would be the same.
Good luck.
- Rick Tyler
Unread 09-02-2005, 20:28
skillinp's Avatar
Unhappy Re: "sandwich" claw
Check this Website:
Good luck.
- Rick Tyler
i searched Divinycell on that site but couldn't find anything. is there somewhere else i could look also?
thx
Abraham Lincoln
Unread 09-02-2005, 20:31
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: "sandwich" claw
Using composites like fiberglass effectively takes some specific skill. If you don't have anyone experienced in it, and especially if you expect to use it on this years robot (its week 5), it's probably a bad idea to get started now. The difference between fiberglass and aluminum, for example, is not huge, but the amount of weight incorrect choice of sizes and thicknesses and gussets etc can add will be much more significant. At this point, you should probably stick to something you are a bit more familiar with.
Team 1257
Unread 10-02-2005, 02:12
Re: "sandwich" claw
Upon sober reflection, I'm with Max. How about forgetting composites for this year and just making your claw out of steel or aluminum? I think there are real advantages to composites for some parts of the robot, but I wasn't thinking it through. I have a certain down-and-dirty understanding of amateur composites from two years of home-boat building. If you are starting from scratch and don't have any epoxy/glass/etc expertise on your team you'd be better off to save it for next year.
Sorry for (maybe) steering you wrong. I answered the question you asked without thinking about whether or not you might have been asking the wrong question -- or at least asking a really adventurous question. (Hey, I'm the guy who wanted to base our whole game strategy on a material that no on else on our team understands.)
It would have been a great Week One question, I think. You can learn more about Divinycell here.
Good luck!
- Rick
Unread 12-02-2005, 15:54
skillinp's Avatar
Re: "sandwich" claw
Good luck!
- Rick
well, we finished it this week. i guess we have decided that we would build a composite of some sort w/alluminum sides
thanks for your help (and we do, by the way, have people experienced with this composite dealie).
Abraham Lincoln
Spring-loaded claw Anubuss Technical Discussion 8 21-01-2005 15:32
Pneumatic Claw cvhsrobotics Technical Discussion 10 17-01-2005 23:26
pic: Claw of doom (571) CD47-Bot Robot Showcase 10 31-01-2004 08:49
The Claw archiver 2001 5 23-06-2002 23:20
The Unvailing of 'THE CLAW' archiver 2000 0 23-06-2002 22:00
