Go to Post It kicked off today, and we already have 10 pages of posts!?!?! - ShotgunNinja [more]
Unread 09-02-2005, 10:41
Teh Mike's Avatar
Teh Mike Teh Mike is offline
Team Scapegoat
None #0414 (Smokie 414)
Teh Mike is an unknown quantity at this point
Send a message via AIM to Teh Mike
Compiling Failed
Today when we attempted to compile a program in MPLAB, it failed, the file in question being user_routines.c. It is only a slightly altered from its original default code and it compiled fine yesterday. Today when we ran it, it came up with a syntax error. I'm pretty sure nothing has changed, (Unless of course gnomes snuck in during the night and edited our program...) since the last time I tested it, so I'm a bit confused. It also doesn't help that I'm the only programmer on my team and I'm fairly new to this... So... Below I've posted the line that's giving us problems, any help would be much appreciated.
void Process_Data_From_Master_uP(void)
I'm sure you all are going to need more than that to help me out, so let me know what you need to see.
<insert witty comment here>
Unread 09-02-2005, 11:22
Electrical Engineer
Rookie Year: 1995
Re: Compiling Failed
Check the function in the code above that line for a missing bracket, "}", or comment which did not end correctly...
Mike Betts
As easy as 355/113...
Rocketboy's Avatar
Rocketboy Rocketboy is offline
Programmer at work, Pilot by heart
AKA: Daniel Schoessler
FRC #1317 (Digital Fusion)
Rocketboy will become famous soon enough
Send a message via ICQ to Rocketboy Send a message via AIM to Rocketboy
The problem is NOT on that line, it's something above that line. A function might be missing a closing bracket or something. Those are easy mistakes to make and can go unnoticed until you build the project. There have been MANY errors like this posted on the forums in the past few weeks, make sure you search before you post.
In order for US to help you, you'll have to post the rest of the file.
-- Unofficial Google Advocate --
I soloed my
"Skyhawk" before I even soloed my car!
Unread 09-02-2005, 11:23
We need at least several lines before and after the line where the error was flagged. It's easiest if you just post the whole .c file.
The problem is probably going to be a typo, a missing bracket, or accidentially typed character before or just after the flagged line.
[edit] Crowded on here this morning isn't it?
Unread 09-02-2005, 11:26
Teh Mike's Avatar
Team Scapegoat
* FILE NAME: user_routines.c <FRC VERSION>
* DESCRIPTION:
*  This file contains the default mappings of inputs
*  (like switches, joysticks, and buttons) to outputs on the RC.
* USAGE:
*  You can either modify this file to fit your needs, or remove it from your
*  project and replace it with a modified copy.
#include <stdio.h>
#include "ifi_aliases.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "user_routines.h"
#include "user_Serialdrv.h"
/*** DEFINE USER VARIABLES AND INITIALIZE THEM HERE ***/
/* EXAMPLES: (see MPLAB C18 User's Guide, p.9 for all types)
unsigned char wheel_revolutions = 0; (can vary from 0 to 255)
unsigned int  delay_count = 7;       (can vary from 0 to 65,535)
int           angle_deviation = 142; (can vary from -32,768 to 32,767)
unsigned long very_big_counter = 0;  (can vary from 0 to 4,294,967,295)
#if _USE_CMU_CAMERA
#include "user_camera.h"
**   VISION VARIABLES      **
int pan_dir=0;
int state=0;
int latch=0;
int latch2=0;
extern unsigned int index_ptr;
extern unsigned int data_rdy;
extern cam_struct cam;
extern unsigned int parse_mode;
int color=0;
const int steering_comp = 30; //steering compenstation (0 to 127)
const int speed_setting = 150; //forward speed setting (127 to 254)
extern int pan_position,tilt_position,tracking;
unsigned int speed_control;
unsigned int cam_state_flag;
void Camera_Processing(void);
#endif
extern unsigned char aBreakerWasTripped;
* FUNCTION NAME: Limit_Switch_Max
* PURPOSE:       Sets a PWM value to neutral (127) if it exceeds 127 and the
*                limit switch is on.
* CALLED FROM:   this file
* ARGUMENTS:
*     Argument       Type             IO   Description
*     switch_state   unsigned char    I    limit switch state
*     *input_value   pointer           O   points to PWM byte value to be limited
* RETURNS:       void
void Limit_Switch_Max(unsigned char switch_state, unsigned char *input_value)
  if (switch_state == CLOSED)
    if(*input_value > 127)
      *input_value = 127;
* FUNCTION NAME: Limit_Switch_Min
* PURPOSE:       Sets a PWM value to neutral (127) if it's less than 127 and the
* ARGUMENTS:
* RETURNS:       void
void Limit_Switch_Min(unsigned char switch_state, unsigned char *input_value)
    if(*input_value < 127)
      *input_value = 127;
* FUNCTION NAME: Limit_Mix
* PURPOSE:       Limits the mixed value for one joystick drive.
* CALLED FROM:   Default_Routine, this file
* ARGUMENTS:
*     intermediate_value    int    I
* RETURNS:       unsigned char
unsigned char Limit_Mix (int intermediate_value)
  static int limited_value;
  if (intermediate_value < 2000)
    limited_value = 2000;
  else if (intermediate_value > 2254)
    limited_value = 2254;
  else
    limited_value = intermediate_value;
  return (unsigned char) (limited_value - 2000);
* FUNCTION NAME: User_Initialization
* PURPOSE:       This routine is called first (and only once) in the Main function.
*                You may modify and add to this function.
* CALLED FROM:   main.c
* ARGUMENTS:     none
* RETURNS:       void
void User_Initialization (void)
  Set_Number_of_Analog_Channels(SIXTEEN_ANALOG);    /* DO NOT CHANGE! */
  /*   Set your PWM output types for PWM OUTPUTS 13-16.
  /*   Choose from these parameters for PWM 13-16 respectively:               */
  /*     IFI_PWM  - Standard IFI PWM output generated with Generate_Pwms(...) */
  /*     USER_CCP - User can use PWM pin as digital I/O or CCP pin.           */
  /* FIRST: Set up the I/O pins you want to use as digital INPUTS. */
  digital_io_01 = digital_io_02 = digital_io_03 = digital_io_04 = INPUT;
  digital_io_05 = digital_io_06 = digital_io_07 = digital_io_08 = INPUT;
  digital_io_09 = digital_io_10 = digital_io_11 = digital_io_12 = INPUT;
  digital_io_13 = digital_io_14 = digital_io_15 = digital_io_16 = INPUT;
  digital_io_18 = INPUT;  /* Used for pneumatic pressure switch. */
     Note: digital_io_01 = digital_io_02 = ... digital_io_04 = INPUT;
           is the same as the following:
           digital_io_01 = INPUT;
           digital_io_02 = INPUT;
  /* SECOND: Set up the I/O pins you want to use as digital OUTPUTS. */
  digital_io_17 = OUTPUT;    /* Example - Not used in Default Code. */
/* THIRD: Initialize the values on the digital outputs. */
  rc_dig_out17 = 0;
/* FOURTH: Set your initial PWM values.  Neutral is 127. */
  pwm01 = pwm02 = pwm03 = pwm04 = pwm05 = pwm06 = pwm07 = pwm08 = 127;
  pwm09 = pwm10 = pwm11 = pwm12 = pwm13 = pwm14 = pwm15 = pwm16 = 127;
/* FIFTH: Set your PWM output types for PWM OUTPUTS 13-16.
  Setup_PWM_Output_Type(IFI_PWM,IFI_PWM,IFI_PWM,IFI_PWM);
     Example: The following would generate a 40KHz PWM with a 50% duty cycle on the CCP2 pin:
         CCP2CON = 0x3C;
         PR2 = 0xF9;
         CCPR2L = 0x7F;
         T2CON = 0;
         T2CONbits.TMR2ON = 1;
         Setup_PWM_Output_Type(USER_CCP,IFI_PWM,IFI_PWM,IFI_PWM);
  /* Add any other initialization code here. */
  Putdata(&txdata);             /* DO NOT CHANGE! */
  Serial_Driver_Initialize();
  //printf("IFI 2005 User Processor Initialized ...\r");  /* Optional - Print initialization message. */
  /* Note:  use a '\r' rather than a '\n' with the new compiler (v2.4) */
#if _USE_CMU_CAMERA
  cam_state_flag = 0;
#endif
  User_Proc_Is_Ready();         /* DO NOT CHANGE! - last line of User_Initialization */
* FUNCTION NAME: Process_Data_From_Master_uP
* PURPOSE:       Executes every 26.2ms when it gets new data from the master
*                microprocessor.
* ARGUMENTS:     none
* RETURNS:       void
  static unsigned char i;
  static unsigned char delay;
  Getdata(&rxdata);   /* Get fresh data from the master microprocessor. */
   Default_Routine();  /* Optional.  See below. */
 Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
  /* Eample code to check if a breaker was ever tripped. */
if (aBreakerWasTripped)
    for (i=1;i<29;i++)
      if (Breaker_Tripped(i))
        User_Byte1 = i;  /* Update the last breaker tripped on User_Byte1 (to demonstrate the use of a user byte)
                            Normally, you do something else if a breaker got tripped (ex: limit a PWM output)     */
#if _USE_CMU_CAMERA
  switch (cam_state_flag)
    case 0:
      delay = 38;              //Wait for at least a second before talking to the camer (26.2ms * 38 = ~1s)
      cam_state_flag = 4;
      break;
    case 1:
      if (camera_init(64,85,50))  // Set the 3 exposure values yellow, green and red
        cam_state_flag = 2;
        Pwm1_red = Pwm2_red = Relay1_red = Relay2_red = 0;
      else
        cam_state_flag = 4;   //Issue continual retries until camera responds
        delay = 19;           //Set delay for 1/2 sec (26.2ms * 19 = ~.5s)
        Pwm1_red ^= 1;      //Flash All Color LED Indicators when camera is not responding
        Pwm2_red ^= 1;
        Relay1_red ^= 1;
        Relay2_red ^= 1;
      break;
    case 2:
      camera_auto_servo(1);  // Turn on auto-servo mode and set servo parameters
      cam_state_flag = 3;
      break;
    case 3:                  // Continue processing
      Camera_Processing();
      break;
    case 4:
      if (delay)
        delay--;
      else
        cam_state_flag = 1;
      break;
#else
  /* Add your own code here. (a printf will not be displayed when connected to the breaker panel unless a Y cable is used) */
 // printf("Port1 Y %3d, X %3d, Fire %d, Top %d\r",(int)p1_y,(int)p1_x,(int)p1_sw_trig,(int)p1_sw_top);  /* printf EXAMPLE */
#endif
* FUNCTION NAME: Default_Routine
* PURPOSE:       Performs the default mappings of inputs to outputs for the
*                Robot Controller.
* CALLED FROM:   this file, Process_Data_From_Master_uP routine
* ARGUMENTS:     none
* RETURNS:       void
void Default_Routine(void)
 /*---------- Analog Inputs (Joysticks) to PWM Outputs-----------------------
  *   This maps the joystick axes to specific PWM outputs.
  pwm01 = p1_y;
  pwm02 = p2_y;
  pwm03 = p3_y;
  pwm04 = p4_y;
  pwm05 = p1_x;
  pwm06 = p2_x;
  pwm07 = p3_x;
  pwm08 = p4_x;
  pwm09 = p1_wheel;
  pwm10 = p2_wheel;
  pwm11 = p3_wheel;
  pwm12 = p4_wheel;
 /*---------- 1 Joystick Drive ----------------------------------------------
  *  This code mixes the Y and X axis on Port 1 to allow one joystick drive.
  *  Joystick forward  = Robot forward
  *  Joystick backward = Robot backward
  *  Joystick right    = Robot rotates right
  *  Joystick left     = Robot rotates left
  *  Connect the right drive motors to PWM13 and/or PWM14 on the RC.
  *  Connect the left  drive motors to PWM15 and/or PWM16 on the RC.
#if _USE_CMU_CAMERA
  if (p1_sw_trig > 0 && tracking > 0) { //If vision active and tracking use camera data
    p1_y = speed_control; //set forward speed
    p1_x = pan_position;  //set turning rate
    p1_x = 255 - p1_x;    //invert turn direction
    // Steering Compensation
    if (p1_x > 135 && p1_x < 225 && steering_comp > 0)
      p1_x = p1_x + steering_comp;
    if (p1_x < 120 && p1_x > steering_comp && steering_comp > 0)
      p1_x = p1_x - steering_comp;
    pwm11 = Limit_Mix(2000 + p1_y + p1_x - 127);
    pwm12 = Limit_Mix(2000 + p1_y - p1_x + 127);
  else
    if (p1_sw_trig < 1) { //If vision not active use joystick
#else
  pwm13 = pwm14 = Limit_Mix(2000 + p1_y + p1_x - 127);
  pwm15 = pwm16 = Limit_Mix(2000 + p1_y - p1_x + 127);
#endif
 /*---------- Buttons to Relays----------------------------------------------
  *  This default code maps the joystick buttons to specific relay outputs.
  *  Relays 1 and 2 use limit switches to stop the movement in one direction.
  *  The & used below is the C symbol for AND
  relay1_fwd = p1_sw_trig & rc_dig_in01;  /* FWD only if switch1 is not closed. */
  relay1_rev = p1_sw_top  & rc_dig_in02;  /* REV only if switch2 is not closed. */
  relay2_fwd = p2_sw_trig & rc_dig_in03;  /* FWD only if switch3 is not closed. */
  relay2_rev = p2_sw_top  & rc_dig_in04;  /* REV only if switch4 is not closed. */
  relay3_fwd = p3_sw_trig;
  relay3_rev = p3_sw_top;
  relay4_fwd = p4_sw_trig;
  relay4_rev = p4_sw_top;
  relay5_fwd = p1_sw_aux1;
  relay5_rev = p1_sw_aux2;
  relay6_fwd = p3_sw_aux1;
  relay6_rev = p3_sw_aux2;
  relay7_fwd = p4_sw_aux1;
  relay7_rev = p4_sw_aux2;
  relay8_fwd = !rc_dig_in18;  /* Power pump only if pressure switch is off. */
  relay8_rev = 0;
  /*---------- PWM outputs Limited by Limit Switches  ------------------------*/
  Limit_Switch_Max(rc_dig_in05, &pwm03);
  Limit_Switch_Min(rc_dig_in06, &pwm03);
  Limit_Switch_Max(rc_dig_in07, &pwm04);
  Limit_Switch_Min(rc_dig_in08, &pwm04);
  Limit_Switch_Max(rc_dig_in09, &pwm09);
  Limit_Switch_Min(rc_dig_in10, &pwm09);
  Limit_Switch_Max(rc_dig_in11, &pwm10);
  Limit_Switch_Min(rc_dig_in12, &pwm10);
  Limit_Switch_Max(rc_dig_in13, &pwm11);
  Limit_Switch_Min(rc_dig_in14, &pwm11);
  Limit_Switch_Max(rc_dig_in15, &pwm12);
  Limit_Switch_Min(rc_dig_in16, &pwm12);
#if _USE_CMU_CAMERA
  return;     //Don't execute the ROBOT FEEDBACK if the CMU camera is used
#endif
 /*---------- ROBOT FEEDBACK LEDs------------------------------------------------
  *   This section drives the "ROBOT FEEDBACK" lights on the Operator Interface.
  *   The lights are green for joystick forward and red for joystick reverse.
  *   Both red and green are on when the joystick is centered.  Use the
  *   trim tabs on the joystick to adjust the center.
  *   These may be changed for any use that the user desires.
  if (user_display_mode == 0) /* User Mode is Off */
  { /* Check position of Port 1 Joystick */
    if (p1_y >= 0 && p1_y <= 56)
    {                     /* Joystick is in full reverse position */
      Pwm1_green  = 0;    /* Turn PWM1 green LED - OFF */
      Pwm1_red  = 1;      /* Turn PWM1 red LED   - ON  */
    else if (p1_y >= 125 && p1_y <= 129)
    {                     /* Joystick is in neutral position */
      Pwm1_green  = 1;    /* Turn PWM1 green LED - ON */
    else if (p1_y >= 216 && p1_y <= 255)
    {                     /* Joystick is in full forward position*/
      Pwm1_red  = 0;      /* Turn PWM1 red LED   - OFF */
    else
    {                     /* In either forward or reverse position */
    }  /*END Check position of Port 1 Joystick
    /* Check position of Port 2 Y Joystick
           (or Port 1 X in Single Joystick Drive Mode) */
    if (p2_y >= 0 && p2_y <= 56)
      Pwm2_green  = 0;    /* Turn pwm2 green LED - OFF */
      Pwm2_red  = 1;      /* Turn pwm2 red LED   - ON  */
    else if (p2_y >= 125 && p2_y <= 129)
      Pwm2_green  = 1;    /* Turn PWM2 green LED - ON */
      Pwm2_red  = 1;      /* Turn PWM2 red LED   - ON */
    else if (p2_y >= 216 && p2_y <= 255)
    {                     /* Joystick is in full forward position */
      Pwm2_red  = 0;      /* Turn PWM2 red LED   - OFF */
    else
      Pwm2_green  = 0;    /* Turn PWM2 green LED - OFF */
    }  /* END Check position of Port 2 Joystick */
    /* This drives the Relay 1 and Relay 2 "Robot Feedback" lights on the OI. */
    Relay1_green = relay1_fwd;    /* LED is ON when Relay 1 is FWD */
    Relay1_red = relay1_rev;      /* LED is ON when Relay 1 is REV */
    Relay2_green = relay2_fwd;    /* LED is ON when Relay 2 is FWD */
    Relay2_red = relay2_rev;      /* LED is ON when Relay 2 is REV */
    Switch1_LED = !(int)rc_dig_in01;
    Switch2_LED = !(int)rc_dig_in02;
    Switch3_LED = !(int)rc_dig_in03;
  } /* (user_display_mode = 0) (User Mode is Off) */
  else  /* User Mode is On - displays data in OI 4-digit display*/
    User_Mode_byte = backup_voltage*10; /* so that decimal doesn't get truncated. */
} /* END Default_Routine(); */
#if _USE_CMU_CAMERA
* FUNCTION NAME: Camera_Processing
* PURPOSE:       Handles trigger buttons from OI and track updates
* CALLED FROM:   Process_Data_From_Master_uP
* ARGUMENTS:     none
* RETURNS:       void
  if (p2_sw_top==1)
    latch2++;
    if (latch2==1)
      pan_dir++;
      if (pan_dir>2) pan_dir=0;
      switch(pan_dir)
        case 0:
          camera_set_servos( 128, 128 );
          break;
        case 1:
          camera_set_servos( 41, 128 );
          break;
        case 2:
          camera_set_servos( 210, 128 );
          break;
  } else latch2=0;
  /* Add your own code here. */
  if (p2_sw_trig==1)
    latch++;
    if (latch==1 ) // This stops the trigger from rapidly cycling through the colors
      // Clear all of the LEDs
      Pwm1_green=0; Pwm2_green=0; Relay1_green=0; Relay2_green=0; Switch1_LED=0;
      color++; // Cycle to next color (must start counting at 1)
      if (color>5) color=1;    // The colors are defined as {1-5} = YELLOW, GREEN, WHITE, RED, BLUE
      // This means you can also say: camera_find_color( GREEN );
      i=camera_find_color(color);
      printf( "COLOR SWITCH %d = %d\r",color,i );
      // This part below sets the LEDs so you can see which color you are tracking.
      switch(color)
        case 1:
          Pwm1_green=1;
          break;   // Yellow
        case 2:
          Pwm2_green=1;
          break;   // Green
        case 3:
          Relay1_green=1;
          break; // White
        case 4:
          Relay2_green=1;
          break; // Red
        case 5:
          Switch1_LED=1;
          break;  // Blue
  else
    latch=0;
  if (camera_track_update()==1)
    // Put vision processing here, because we have a good frame!
    printf( "Got T packet %d %d %d %d servo: %d %d\r",cam.x,cam.y,cam.size,cam.conf,cam.pan_servo,cam.tilt_servo );
    if (cam.size > 0 && p1_sw_trig>0) {     //Check to see if camera is tracking
      tracking = 1;               // if yes then set 'tracking' flag
      pan_position = cam.pan_servo;
    else
      tracking = 0;               // if there is no track, clear the flag
#endif
There you go.
And I always search before I post, I just couldn't find this exact problem. Believe me, if I just immediately posted everytime, I would own this forum.
Unread 09-02-2005, 11:29
Like Mike said, No closing bracket in the routine before the error line.
So, yes gnomes snuck in during the night and edited your program (and don't think they won't do it again!)
Should be:
Unread 09-02-2005, 11:34
sybert1ger's Avatar
sybert1ger sybert1ger is offline
The Systems Engineer
AKA: JR
FRC #0078 (AIR Strike)
sybert1ger will become famous soon enough
I think you need a closing bracket after these two lines in the User_Initialization() function.
} //<-Add this
Unread 09-02-2005, 13:27
Teh Mike's Avatar
Team Scapegoat
Many thanks, you guys rock.
the application failed to initialize properly (0xc0000033) white_ChocOlat8 Inventor 5 25-08-2004 22:40
Problems With Compiling KWalsh Programming 5 23-02-2004 16:11
Compiling Problems Chris Hleva Programming 11 20-02-2004 17:12
White Paper Discuss: IFI Loader for Linux with compiling instructions CD47-Bot Extra Discussion 1 09-02-2004 16:46
Problem compiling edubot Ben B Programming 3 14-01-2004 00:51
