Go to Post I think this is the forest that ChiefDelphi often misses as we're picking the branches off every tree. - Libby K [more]
Unread 09-02-2005, 18:57
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
Servo Values
Does anyone know what values the servo outputs in accordance to its angle?
Thank you,
Unread 09-02-2005, 19:25
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Servo Values
The Hitec servos go through 180º and 255 PWM units. Thus, a difference of 1 PWM unit translates to (180/255)º of rotation. 127 is dead center, so you should be able to figure out how far you are from center.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 09-02-2005, 19:37
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Re: Servo Values
The only output from the servos we got is the motion. They don't return feedback about their position.
Unread 09-02-2005, 19:51
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Re: Servo Values
Are you talking about from the camera board? If yes, sure you can get the position. If no, what are you talking about?
_
Unread 09-02-2005, 19:53
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: Servo Values
That information you get from the CMUcam is not feedback from the servo, it is just the value the CMUcam sends to the servo. It may actually be in a different position (like if there is a large load on it)
Team 1257
Unread 09-02-2005, 19:56
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Re: Servo Values
That's true, but with any luck, there really shouldn't be any huge loads on your camera servos.
_
Unread 11-02-2005, 09:07
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Re: Servo Values
The servos go through 180 degrees, but when I test them out with the default program, I put them on pwm01, they only move 100 degrees or so. Is this because the joysticks don't go through the entire range? If it is this it isn't really a problem for us because the servos will be controlled but a button to output a value, not an analog input.
Thanks
Unread 14-02-2005, 14:56
roboticsjenkins's Avatar
roboticsjenkins roboticsjenkins is offline
robotics_jenkins
AKA: Andrew
#0616 (Southampton Indian Robotics)
Team Role: Electrical
roboticsjenkins can only hope to improve
Send a message via AIM to roboticsjenkins Send a message via Yahoo to roboticsjenkins
Re: Servo Values
How do you set the camera servo pan and tilt limits? We would like to change them from 46 and 210 to our own values. We assume you do it in camera.c under camera_set_servos. But we have been unsucessful so far. Please Help
Unread 14-02-2005, 15:49
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Re: Servo Values
We tested our servos and found that (145 degrees : 160 sv units) which is .906 degrees per servo unit. 180 degrees : 255 sv units would be .706 degrees per servo unit.
I will have to retest...
Dashboard View of Pan and Tilt Servo Values JoeXIII'007 Programming 1 02-02-2005 22:34
A testimony to my unique FIRST experience: Ken Leung General Forum 22 14-04-2004 20:45
What is wrong with this code???? It won't Compile and I don't know why? Please Help CrashZero Programming 23 26-03-2004 09:44
