Go to Post It's very confusing to other people on the message boards when you make things up that are incorrect and assert them as fact. Please don't do this. - Dave Flowerday [more]
Unread 10-02-2005, 12:21
reilly reilly is offline
reilly is an unknown quantity at this point
Pneumatics-Code [and piston output length]
What is the output [piston length] of the given piston, in other words, how much does it extend?
Also, does the FRC_default.hex or FRC.hex supply functions for pneumatics,pwm signals for pneum. solenoids?
Unread 10-02-2005, 16:10
Re: Pneumatics-Code [and piston output length]
At the risk of sounding unhelpful, that depends on the length of the piston.
You don't control solenoids with pwm signals. You control them with relay signals via a Spike. The default code copies a bunch of joystick buttons to relay outputs. Look at the user_routines.c file and search for the Buttons to Relays section.
Unread 10-02-2005, 16:57
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
A pistons length is about 2 " longer than the throw when in closed position. Therefore a 4" throw would give a 6" in length piston closed or 10" when open. This is a rule of thumb and not exact. Smaller throws still need minimum 4 "
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 10-02-2005, 19:05
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
I believe he is asking about how to control how long the piston extends in code. There is no easy way to do this without sensors, feedback, and multiple solenoids per cylinder. If it really is important, search multipositioning with cylinders for some help on the topic.
Team 1257
Unread 10-02-2005, 19:57
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
We did this last year. The key for us was a solenoid that centers when there is no power (Meaning if relay1_fwd == 0 and relay1_rev == 0, no air would move). Otherwise, you can use 2 solenoids: one as a go/no go, the other for direction. See the shoulder_* functions in grabber.c in the 1227 code for an example.
Unread 13-02-2005, 11:42
Actually, I was refering to the only given cylinder that came with the kit, the pneumatics manual doesn't give the specs for the given cylinder [not all those you can order].
Is there any difference between throw and stoke?
P.S. Yes I was asking about pwm control: thank you for the coding tip [link].
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Kevin Watson's encoder code with RPM output MaxM Programming 2 05-02-2005 00:06
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
