Go to Post I looked at it and originally thought it was a crazy idea... then I looked at it again and it still sounds like a crazy idea. But crazy ideas tend to produce some excellent results. - Yipyapper [more]
Unread 10-02-2005, 16:06
WhiteTiger WhiteTiger is offline
WhiteTiger will become famous soon enough
Question wiring questions (pwm)
we have 2 questions about the wiring for this year, both involving the pwm's:
1. What are the black, yellow, and red wires for, and do they allow 2 victors to run parallel?
2. How do the black, red, and white wires fit into the new blue 884's? They dont fit as they did in the red 884's we used last year.
Unread 10-02-2005, 16:14
D.J. Fluck
Posts: n/a
Re: wiring questions (pwm)
1. The Red Black and Yellow PWM cables are for running two motors off one switch, joystick or whatever you decide to use. Say for example you have a 2 motor drivetrain and you want both of them to go forward by pushing the left joystick forward. You would connect the two male ends to the victor the two drive motors are plugged into and then the female end would go into PWM port 1 on the RC (assuming your joystick or switch is plugged into operator interface port 1)
2. Directly from the IFI Victor Users guide
The male PWM cable connector connects to the
speed controller. The Victor housing is design to
provide a firm connection. Trim the shroud corners
slightly if necessary for insertion into the Victor.
For more info see www.ifirobotics.com
more specificially http://www.ifirobotics.com/docs/ifi-...nual-dec04.pdf
Unread 10-02-2005, 16:16
#1) Those cables are intended to be used to drive two victors or spikes with the same PWM signal.
#2) There are tiny plastic pieces blocking the insertion of the cable in this year's Victor. You can scrape them down until the connector fits into the Victor.
Unread 10-02-2005, 16:32
thanks guys!
47 Questions! Matt Krass Games/Trivia 52 19-04-2006 00:58
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
**FIRST EMAIL**/Autodesk Inventor Training and Technical Questions Information Rich Wong FIRST E-Mail Blast Archive 0 07-12-2004 17:22
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
