Electronics visible?
Another electronics question (and we couldnt find this one in the rules...
)last year we had to have the electronics visible, and we assumed the same for this year until we hit a design flaw that wouldn't happen if the electronics needed to be visible. In the rules, there is nothing (that we could find, anyway...) that says the electronics need to be visible. So do they need to be visible again this year, or can we keep our same design? thanks! ![]() |
Re: Electronics visible?
The LEDs in the robot controller needs to be visible and the breaker must be easily accessible.
Yeah, the RC status lights must be visible. But whether or not the rest of the electronics are visible during a match, you definitely want the robot to be inspectable at competition. I wouldn't hide things so well that you have to disconnect parts in order to get to the electronics.
In section 5 - The Robot, check out R57 and R58.
R57 says that the RC indicator lights must be visible at inspection and during the competition. R58 says that all circuit breakers must be visible for inspection. "Them's the rules" |
Not mentioned anywhere else, the spikes and victors have lights that although they don't need to be visible, helped us out more than once.
I think, in summary, that it's part rule, part good idea. Sparks |
yea thanks guys!
knowing our team, we'll need to make MANY adjustments... It's easy enough though...i think we have an idea to make most of the electronics visible and the rest easily accessible if anyone was in Annapolis last year, we were the team that had a drill motor brake on us, and as a result, only half our robot worked in the last competition... ![]() so we know the importance of easy maintenance ![]() |
#7
I remember last year the inspectors were also looking to make sure out pump valve was clearly accessable... we had it buried within our drivetrain and although they didn't disqualify us, they didn't seem to like the idea.
#8
They also wanted the "Robot Reset" button accessable when they inspected us at Sac.
#9
Well, as far as I know, it's not stated in the rules, but it would be a good idea to keep you robot controller's LEDs visible. We found it could be useful at the end of a match when your robot does something totally unexpected and you want to know what happened. Next, you look at the robot controller's LEDs (which are still being powered by the backup battery) and you notice the problem with a red LED. You go back to your pit area, fix the problem, and it doesn't happen again. If you're looking for a material for see-through material, try lexan. It was protective enough for us last year and we were still able to see our LEDs on the robot controller.
| Programming and Electronics — Getting Started | Sidney San Martín | Technical Discussion | 7 | 12-01-2005 15:25 |
| Books on electronics relating to robotics | patrickrd | Technical Discussion | 1 | 15-05-2004 21:28 |
| Covering Electronics | shyra1353 | Rules/Strategy | 6 | 24-02-2004 22:23 |
| Professional electronics board assembly [annotated collector's edition] | Geoff | General Forum | 7 | 17-02-2004 21:57 |
| Question about buying electronics | _GP_ | General Forum | 5 | 01-02-2004 12:43 |
