Go to Post now now, there is no such thing as reading the manual too much. I read it every night just before I go to bed. - 663.keith [more]
Unread 10-02-2005, 17:10
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
mounting vertically
are there any disadvantages to mounting electronics (RC, Breaker) vertically
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 10-02-2005, 17:19
Emily Pease's Avatar
Emily Pease Emily Pease is offline
Nobody puts Baby in the corner.
FRC #0125 (NU-TRONS)
Emily Pease is a name known to allEmily Pease is a name known to allEmily Pease is a name known to allEmily Pease is a name known to allEmily Pease is a name known to allEmily Pease is a name known to all
Send a message via AIM to Emily Pease
Re: mounting vertically
We mounted the electronics vertically last year. The only disadvantage was that it was really hard to get to all of the components, but that was not due entirely to it being vertical; it was mainly because everything was crammed together. If you can make the layout so that everything is relatively tidy and accessible, and that the RC is visible, there should not be a problem.
Unread 10-02-2005, 17:24
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
We found that when you mount an RC vertically, you are more likely to have PWM cables come detached. (The weight of the wires can pull them down and out.)
Take this into consideration.
John
Unread 11-02-2005, 08:29
John
This is a big disadvantage, but secure the cables with tywraps. Be sure to include a service loop so you don't put too much strain on the pin on the RC.
We have mounted our electronics vertically in the past, it all depends on the design and where we can fit stuff.
Unread 11-02-2005, 08:51
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Last year we mounted our RC vertically, it worked fine...though the rest buttons were at the bottom and kind of a pain to get to. Plus it was hard to wire some of the stuff towards the bottom - though that may have been since it was very close to other componets.
Everything else should be fine...cept I think verticle speed controllers would just suck up more metal scraps.
This year the one thing our programmers wanted (well one of the things) was having the RC mounted flat so that it was easier to get to (though we're extended all of our wires from it - the reset, the prog switches and the tether and program ports).
We were thinking of putting the circuit panel vertically, but it seemed kinda hard to push the breakers in and we were afraid it would have enough support.
Overall it doesn't matter, just make sure things that need to be visible (i.e. the RC) are and things are easy to get to if need be.
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Where are you mounting the camera? GregG Programming 7 27-01-2005 00:44
Mounting Electrical Parts SpaceOsc Rules/Strategy 21 15-10-2004 22:52
drill motor mounting whynot Technical Discussion 3 03-02-2003 08:24
Complications/restrictions of vertically mounted controll panels BOBBEY!!!! General Forum 15 14-01-2003 22:54
new bosch pinion and mounting ajlapp Motors 1 08-01-2003 17:16
