Go to Post When you start new threads, keep in mind that ChiefDelphi has about 14.6 million subforums about nearly everything you can imagine in the world of FIRST. You have to be in the forum you'd like for your thread to appear in when you choose to start a new topic. - Madison [more]
Unread 12-02-2005, 00:36
Bleric's Avatar
Bleric Bleric is offline
#0624 (CRyptonite)
Bleric is on a distinguished road
Send a message via AIM to Bleric Send a message via MSN to Bleric
Question breaker tripping on robot startup
Alright, I'm just a programming monkey, so my knowledge about wiring is a little... sketchy, to say the least.
The thing is, every time we power up our robot, it trips the breaker panel. We can push the reset button, and everything works normally. Also, when we unplug every one of our motors, this does not happen - the panel is not tripped. (We only have our four CIMs for the drive train hooked up at the moment.) If we plug in any one of our CIMs, the breaker trips when we turn on the robot. (and works normally when we reset the breaker.) It's almost like the motors are drawing a huge amount of current right when we first power up.
Anyone know what might be causing this?
Unread 12-02-2005, 04:38
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: breaker tripping on robot startup
Alright, this might be a stupid question, but do you have speed controllers between the breaker panel and your motors? If not, that would be your fix.
If you do have the speed controllers, I would check to make sure that the code has them in neutral (well...not full) when it starts. If it's not neutral, they'll start pulling current.
Also make sure that you don't have any shorts anywhere. Connect everything (except the battery) and use a meter to check for continuity between power and ground (go through the battery connector).
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 12-02-2005, 10:25
I think you are really meaning that the trip light on the breaker panel shows a tripped breaker when you first turn on. This may be a normal condition just hit the reset and practice. See what happens. This could be happening if you are starting up enabled and ready to go. The power on condition occurs when all the motors including a pump, are turned on at the same time. If you don't trip other times don't worry about it.
If it continues, suspect a short or defective breaker and fix the problem. IFI is always open for questions.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
Shifting Gears MBosompra Technical Discussion 71 23-07-2004 02:49
what kind of robot will win? Bcahn836 Championship Event 44 12-04-2004 00:02
60 amp breaker Anne Lam Technical Discussion 10 10-01-2002 15:13
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
