Go to Post (This is why Non-Engineering Mentors make the dinner plans for the team...) - KathieK [more]
Unread 12-02-2005, 00:52
neilsonster's Avatar
neilsonster neilsonster is offline
AKA: Andrew Neilson
FRC #0772 (Sabre Bytes)
neilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to all
Send a message via MSN to neilsonster
Code Violations...
Hi, I am having tons of trouble getting the rc to recognize the camera in autonomous right now. It works fine in user_routines but in user_routines_fast I am getting code violations whenever I call camera_init, camera_find_color, or camera_auto_servo. I have #included camera.h (I'm using Kevin Watson's "cumulative" camera files). I have tried creating a function within camera.c and then just calling it from user_routines_fast, and it was getting violations whenever any of those 3 functions were called. Please, please, please, does anyone have any ideas about this? Thank you for any assistance!!!
Unread 12-02-2005, 18:26
Mohsin's Avatar
Mohsin Mohsin is offline
building...building...bui lding...
FRC #0772 (Club Sandwhich)
Mohsin is on a distinguished road
Send a message via MSN to Mohsin
Re: Code Violations...
will any one help? because we are totally lost, on this and are racking our brains out.
thanks
first is like an ex-girlfriend, once she leaves, you ache for her more.
Unread 12-02-2005, 18:32
AIBob's Avatar
AIBob AIBob is offline
AI Programmer
AKA: Bob Frank DOT org
FRC #0358 (Hauppauge Robotic Eagles)
AIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to beholdAIBob is a splendid one to behold
Send a message via ICQ to AIBob Send a message via AIM to AIBob Send a message via MSN to AIBob Send a message via Yahoo to AIBob
What errors did you get?
- from B B frank
Unread 12-02-2005, 18:41
Mohsin's Avatar
(this is neilsonster)
The code violation light blinks.. that's it. When I remove all three of those (camera_init, camera_find_color, or camera_auto_servo) from user_routines_fast it runs fine, but I can't do anything with it. When I add any one of them back in I get the blinking light again. The code builds fine.
Unread 12-02-2005, 19:16
AKA: Andrew Neilson
Yes!!! I just fixed it! The problem was that I was not using #if _USE_CMU_CAMERA and i had taken it out of all the code... funny thing is that every single problem I have had programming has been solved by going back to the default routine.
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
