Go to Post Einstein 2015 was just a tryout for FIRST's next warehouse forklift operator. - Jay O'Donnell [more]
Unread 12-02-2005, 01:22
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Accelerometer Bias
I've made our own gyro/accelerometer code because I wanted to do some various things other than what Kevin Watson's code (which is excellently made) did. The gyro code works fine now, however because of the accelerometers' extreme sensitivity, I was wondering how you can make a code to remove the accelerometer bias. My code gets it between 511-512... but since it's an int it goes one way or the other... and by having it at 511... it is enough to quickly make the robot velocity appear as though it is getting negative.
Has anyone else made their own accelerometer code and found a way to fix this? Thanks!
Unread 12-02-2005, 02:12
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Re: Accelerometer Bias
This is one of the reasons I oversample the gyro and accelerometer outputs. If you look at my gyro code you'll notice that I sum GYRO_SAMPLES_PER_UPDATE samples and treat that value as though it was a single sample. It's a simple way to get a little more accuracy in your calculations.
-Kevin
Kevin Watson
http://kevin.org
Unread 12-02-2005, 03:40
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
-Kevin
Hey Kevin,
I havn't looked at your code, but wouldn't you need to divide SUM_OF_SAMPLES by NUMBER_OF_UPDATES, so you would get an avereage value?
I know theres nothing wrong with it, i mean.... hundreds of teams use it, just wondering what exactly you ment...
Thanks,
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 12-02-2005, 04:05
FRC #2429
Originally Posted by Leav
...but wouldn't you need to divide SUM_OF_SAMPLES by NUMBER_OF_UPDATES, so you would get an avereage value?
Yes, you can do this or just change the units (e.g., volts per eight samples rather than volts per sample).
-Kevin
Kevin Watson
http://kevin.org
Accelerometer Timer Question psquared Programming 3 12-02-2005 01:34
URGENT! We need help with the accelerometer lkdjm Electrical 5 11-02-2005 16:42
Accelerometer Wiring/Input DAN THE MAN Control System 1 06-02-2005 20:02
Accelerometer vs Gear Tooth Sensors zdeswarte Electrical 4 22-01-2005 15:35
Example accelerometer code released. Kevin Watson Programming 0 20-01-2005 03:45
