Where can i purchase a Gyro?
Ok, my team has finally decided to buy a gyro. We want to know what our restrictions are. I've gone over the rule book a couple of times, and i don't see it. If you guys could tell me where to find the stuff on buying a gyro, please tell me. If you'd like to post up directly, that would be fine too :-D
Re: ASAP PLEASE!!!!!!!!!!!!!!11
Make sure it fits through the parts flow chart
That's about all the help I can offer...Did you search through the questions and answers though and here at Chief Delphi?Also try being more descriptive in your titles. |
lol, sry about that. My thread name is just to attract people to come here. Caps usually get more people to come because our eyes mostlikely are more attracted to things that look different than everything else. But back to topic.....
According to our mentor - you can use any gyro that fits within the costs reqs. |
ah, thank you.
#7
Re: Where can i purchase a Gyro?
You may purchase the gyros directly from Analog Devices, www.analog.com or digi-key, www.digikey.com. Analog Devices provides evaluation boards, for their gyro product line, which will let you wire it fairly easily.
The parts of interest are the ADXRS300EB, the ADXRS150EB, and the ADXRS401EB. These are the evaluation boards and have the following sensitivity: 300°/sec, 150°/sec, and 75°/sec, respectively. I just checked digi-key's site and the 150EB is in stock. I would recommend going to Radio Shack and buying a soldereable breadboard. Actually buy a 20-pin IC socket (also at R Shack) and solder it to the board. In this way, you can easily remove the sensor. Solder a PWM cable to the breadboard, as described by Kevin Watson, http://kevin.org/frc/. You should be good to go. |
| Updated: Example Gyro Interface Code | Kevin Watson | Programming | 2 | 28-03-2005 04:36 |
| Example gyro code released. | Kevin Watson | Programming | 60 | 17-03-2005 18:32 |
| Gyro Troubles | SteveO | Programming | 13 | 30-01-2005 16:46 |
| No Signal From Gyro | colt527 | Programming | 12 | 19-10-2004 07:30 |
| Wierd gyro code problems...pls help | Salik Syed | Programming | 4 | 14-03-2004 01:29 |
