Go to Post The point of FIRST is not to create pretty robots. It's to teach kids about science, technology, and engineering. - Cory [more]
Unread 13-02-2005, 01:39
ten3brousone's Avatar
ten3brousone ten3brousone is offline
Kurayami o Samayou
None #1160
ten3brousone is an unknown quantity at this point
Banner Sensor Help
Hey, head programmer from team 1160 currently trying to find a way to use banner sensors. did a search looking for information regarding how to actually read the input from the banner sensor, or also called line tracker, its the yellow thingy. And yet i couldnt find a manual for it nor the variable names and input types of the device, any help would be appreciated thanks
-Rookie plz bear with me thanks!
Unread 13-02-2005, 11:05
Re: Banner Sensor Help
There are several different types of Banner optical sensors. I think the electrical connections are all similar: provide it with 12 volt power and ground, and it produces a signal which is either open or grounded. You can find specific data sheets at http://www.bannerengineering.com/lit...ct_literature/ (choose from the Photoelectric Product Line menu).
The Banner sensor output should be connected to a digital input on the Robot Controller. It is read just like any other such input (e.g., rc_dig_in10 if it's on digital input 10).
Banner Sensor as encoders on a Arm? thoughtful Electrical 6 18-01-2005 00:29
Segway Banner Ad JohnBoucher Dean Kamen's Inventions 3 09-10-2004 14:19
Banner Sensor Programming Problem 2Crisis Programming 4 24-02-2004 13:40
banner sensor positioning and times bob1million Programming 4 16-02-2004 13:40
Is there a size regulation for the pit area if we wanted to put up a banner Ragin_Kage General Forum 6 14-03-2002 15:33
