Go to Post There is something completely respectful and amazing to see FIRST teams who have members go through 4 years of the program without winning a single competition or even a single award. Those are the teams that are looked at by others and respected for what they do. - fuzzwaz [more]
Unread 14-02-2005, 14:01
BillCloyes's Avatar
BillCloyes BillCloyes is offline
#0677 (The WireStrippers)
BillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura aboutBillCloyes has a spectacular aura about
Question PWM cables: too fragile? what fixes/precautions?
Has anyone else (over the years, or lately) been having problems with PWM cables going/being bad?
I don't think that my team is particularly hard on stuff (especially things that are ~$5 a piece) but each year we seem to run into problems with some the PWM cables working only intermittently, or just not working at all.
...and before I get the warnings... No, We do not do any of the following:
* route them beside power wires
* do things to/put them in places that would take off insulation
* fold/crease the wires
* use them as "structural" or "fastening" members, etc...
After 5 years of this same problem, I am guessing that this afflicts most other teams as well. What works to counteract this?
Any help would be greatly appreciated
-Bill
Unread 14-02-2005, 14:05
Re: PWM cables: too fragile? what fixes/precautions?
-Bill
Bill,
We have PWM cables go bad from time to time. It happens, we suspect that for some reason the pins change size or lose their spring and just give high resistance. When in doubt, throw it out.
Unread 14-02-2005, 14:09
BillCloyes's Avatar
Originally Posted by Al Skierkiewicz
Bill,
I agree with you there...it is just that it gets expensive!
-Bill
Unread 14-02-2005, 14:22
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Bill,
Every year we have problems with seating our PWM cables, whether they are the ones supplied in the kit or ones we crimped ourselves.
This year, 5 out of 6 of our cables running to our Victors failed to work properly the first time we connected them. All 4 of 4 cables running to the Spikes worked fine however.
The difference was our PWM pins were missing the PWM connector on the Victors. All 5 of the cables that failed were inserted improperly. When we removed them, you could see all 3 pins were very slightly deflected in the same direction, meaning they'd missed their holes. Straighten them out, and re-insert the cable. Use as little force as possible to insert the connector, and if you encounter any kind of resistance, the pins are likely missing the connector and are being bent.
As for the actual IFI-supplied cables failing, we'd yet to have one fail other than from broken pins due to repeatedly mis-inserting them. Carefully re-inserting them always fixed the problem.
Hopefully you are having the same problem we are, and won't have to burn a hole in your budget replacing PWM cables!
-SlimBoJones...
Unread 23-02-2005, 00:17
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
victors spikes and pwm cables
Ok, before we shipped our robot, we noticed that the pwm cables kept falling out of the victors and spikes. Is this happening to others or just us? How should we fix it. I think hot glue. Also was pluging in the pwm cables into the victors more difficult then last year?
Unread 23-02-2005, 01:30
Re: victors spikes and pwm cables
Judging from other threads this year, I'd guess that more people had trouble getting theirs seated properly in the first place then having them falling out.
Unread 23-02-2005, 02:14
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
We had problems with the PWM cables making decent connections to the RC.
Hot glue? Ugh. I suppose that'd work, but only as a last resort. Just use a tiny bit (just enough to be able to slice with an exacto knife in the event of a problem).
Plugging the cables in was MUCH harder this year .. because IFI shipped em with those little plastic tabs where the cable plugs in. Its a simple fix with a small knife, but cutting into those little $120 blocks of plastic scares the crud out of me.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 23-02-2005, 02:24
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
This years speed controllers and relays gave us alot of headahces too. Alot of the connections were 'iffy' at best. Sometimes bending the pins and reinserting the PWM cable into the relay/SC helped, but it never felt like the correct solution. Hopefully IFI knows of these problems and is working on correcting them because the plastic housings are simply not as good as they have been in the past. An 'iffy' connection is not okay in my book. I put my trust in IFI to resolve the problem, because they have done such a great job in the past. I never imagined a simple thing would give us so many problems.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 23-02-2005, 11:25
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
We also found the connections on this year's Victors to be marginal at best. We file down one corner of the cable connector to get it to fit, but I don't trust it. We're grabbing last year's off the old bot and will swap them out at competition, as we are allowed to use ANY 884 model.
Steve
Unread 14-03-2005, 14:30
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
We have had a lot of problems with these connections. So far I have had to replace 3 pwm cables and 1 speed controller. The alignment of the connector is very very difficult, if not impossible. Be careful if you do decide to help the situation by cutting or filing the corners (provide relief) as the plastic may fall into the connector hole. We found some clips that slide in over the connector once they are seated and under the speed controller body - problem is that we have the speed controllers velcro'd down so they won't move around.
Still looking for a better way than hot glue to keep those little buggers from coming out as easily.
Unread 23-02-2005, 11:36
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
our team was thinking of making our own PWM cables next year.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 23-02-2005, 12:33
If you want a good result, make sure you use a high-quality crimper designed for the task. I made a couple of PWM cables with pliers instead of crimpers, and I took a very long time verifying the crimp, so they're okay -- but I wouldn't want to make a habit of it.
Unread 24-02-2005, 01:58
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
I rarely have any problems with PWM cables aside from them falling out.
My team's worst problem last year is when a PWM cable fell out of an upside-down Victor during a round, causing the robot to only turn one direction and creating a hard struggle to plug it in afterwards.
This year, if one of them falls out (it's a Y-cable), it could ruin our gearbox, which would basically prevent us froom competing. I think that we should hot-glue them in.
My biggest problem with cables this year is the camera cable.
I already shipped the camera, so I will have to fix it at the competition, but the Camera cables are the worst. They keep getting bent because they have to wrap around to the front of the camera, and the TTL Serial cable is bad because a little bit of plastic on the tiny circuit board got chipped off, and causes it to fall off a lot.
Part of this problem was because some people on our team decided to mount the electronics upside-down on my test bot!
The reason this is so bad is that it causes the code to freeze when the camera stops responding, giving a red flashing "Program State" (Code Violation) error on the RC, stalling the program for the rest of the match. The remote reset button might work, but definately only after Autonomous mode.
If there is any cable I'll be hot-gluing in, it's the TTL and the camera power!
There's still always a switch on the camera itself.
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
Unread 24-02-2005, 07:39
Originally Posted by ace123
...The reason this is so bad is that it causes the code to freeze when the camera stops responding, giving a red flashing "Program State" (Code Violation) error on the RC, stalling the program for the rest of the match...
This behavior can be changed. Remove the FREEZE_ON_ERROR definition and recompile the code.
Unread 24-02-2005, 12:59
We had so much trouble with the PWM cables plugging into the Victors that we now have a team member who is the designated Cable Guy. He plays the piano and has long, thing fingers. First time every time. We'll be glad to rent him out for tournaments for a modest donation to our '06 campaign fund...
FYI about using PWM 13-16 with interrupts cabbagekid2 Programming 6 22-01-2005 00:54
Using an Operator Interface with the 2004 EDU RC wirelessly Dave Flowerday Robotics Education and Curriculum 34 19-04-2004 19:06
In need of PWM Cables! SOON! Travis Covington Electrical 2 19-02-2004 20:55
Can we shorten the PWM cables? RAWdealer59 Electrical 3 18-02-2003 15:49
Loss of signal in PWM cables. archiver 2001 6 23-06-2002 23:29
