Go to Post There's lots of other "stuff" that make a team work well in the FIRST environment, beyond designing and building a robot. - KathieK [more]
Unread 16-02-2005, 21:30
groves groves is offline
Steve Liggett
None #1213 (Groves)
groves is just really nicegroves is just really nicegroves is just really nicegroves is just really nicegroves is just really nice
pic: 1213 GROVES HS / TARDEC LIFT SYSTEM
Unread 16-02-2005, 21:33
blue_crew blue_crew is offline
MADTOWN ROBOTICS!!
AKA: Daniel Sheeter
FRC #1323 (Madtown Robotics)
blue_crew is on a distinguished road
Send a message via AIM to blue_crew Send a message via MSN to blue_crew Send a message via Yahoo to blue_crew
Re: pic: 1213 GROVES HS / TARDEC LIFT SYSTEM
can you please give some more information about your spools. we want to know if it can be modified to allow for pneumatic tubing.
thanks and it looks awesome!
Unread 16-02-2005, 21:38
Kyle's Avatar
Kyle Kyle is offline
Mike Wade, RIP You will be missed
AKA: Kyle Rice
FRC #0365 (MOE)
Kyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond reputeKyle has a reputation beyond repute
Send a message via AIM to Kyle
How high can you lift?
2007 Championship Chairmans!!!!! 8 years in the making GO MOE!
Facebook
Unread 16-02-2005, 21:46
Steve Liggett
None #1213 (Groves)
the highest part of our robot reaches 13.5 feet and can withstand a emergency stop with one tetra all the way up.
Unread 16-02-2005, 22:57
haroony341's Avatar
haroony341 haroony341 is offline
FRC #0341 (Wissahickon HS & NMTCC) FRC#2234 (The Episcopal Academy)
haroony341 is an unknown quantity at this point
Send a message via AIM to haroony341
hey, can you post the white papers (or email if you prefer) on how you put that together.we came up with the idea to use something like that to hold the slack on the pulley system for our arm but we werent sure how to do that.
thanks!!
Unread 17-02-2005, 06:24
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Well. It's not as easy as Steve made it sound. First off, the total cost - not counting the 14 ga. wire - is about $50. Secondly, it took an incredible piece of luck to come up with a reliable setup.
The reel is a plastic clothesline reel available at either Home Depot or Lowe’s. The bulk of the $50 comes from the 14 ga. triple tap extension cord reel - also at Home Depot. The slip rings from the power cord reel fit perfectly in the clothes line reel's hub. I do mean perfectly!!
The remaining $10 is where the real (pun) lucky part comes in. The actual reel in the Home Depot clothesline retractor was made of PVC with a metal side that held the coil spring in. The metal side was attached to the PVC by melted tabs, which disintegrated in no time. The resulting slop caused the slip rings to loose contact. Just so happened that I’d also bought a couple of the clothes line reels from Lowe’s – same manufacturer, but different, those had metal mounting brackets and, more importantly, the actual reel was made of nylon with twice as many tabs, which were also melted to hold the metal side. My guess is that the one that Home Depot still sells does not survive many washdays; and that Loews now sells the upgraded version.
Alas, they also upgraded the case to include a collar around the spindle for the reel, wicht meant that the slip ring contact legs were no longer a perfect fit. So, we needed the POC clothesline reel for the case, and the “new improved’ one for the reel. That’s how we end up spending $50/per. J
I can post the part numbers if anyone is desperate enough to try. Even though I’ve found out time and again that Lowe’s carries better stuff than the crap you find at Home Depot, I can’t guarantee it.
As for pneumatics – Hummm, you’d need some kind of slip connection. And that plastic reel can hold 20’ of ~3/16” dia. Clothes line – but they do sell a 50 footer.
Slack on pulley system – now you’re talkin bout something that may work for you – especially if it’s something like Spectra String. Just pull a bunch of the clothes line out, cut it where you feel it’s the right tension – attach it to the cable – it should pull it right back into the reel.
This message is hidden because Jack Jones is on your ignore list.
Unread 16-02-2005, 21:43
Steve Liggett
None #1213 (Groves)
I don't know how you would do it with pnuematics. you should pick one up at the home depot and play with it I think there 8 bucks. It's a clothes line reel.
pic: TEAM 1213 GROVES HS CD47-Bot Robot Showcase 9 14-02-2004 11:02
pic: TEAM #1213 CD47-Bot Robot Showcase 17 13-02-2004 21:26
pic: rookie team 1481's 6 cylinder pneumatic system. (very organized isn't it...) CD47-Bot Robot Showcase 3 02-02-2004 23:19
pic: Rocket City Robotics (34) Rapid Prototyping System CD47-Bot Extra Discussion 8 08-01-2004 21:13
pic: Drive System CD47-Bot Robot Showcase 3 27-02-2003 14:11
