Go to Post I'm in it for the challenge, winning is just a side effect... - davidthefat [more]
Unread 17-02-2005, 13:23
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Common Ground on Limit Switches
We have 4 limit switches on our arm and it would be great if we could run only one ground wire out there. Is there any problem connecting all for to the same ground pin on the RC? Could we add a couple of optical encoders to the ground also?
Thanks.
Unread 17-02-2005, 13:33
Re: Common Ground on Limit Switches
All the grounds of the digital in/out pins on the RC are common. As long as you don't have too much current flowing, or run the wires too closely in parallel with motor leads, you'll probably be fine running a single ground to all your switches.
Unread 17-02-2005, 13:49
phillutz phillutz is offline
FRC #0851 (The Froggers)
phillutz is on a distinguished road
We are currently connecting 11 digital using 1 ground pin.
Works fine.
You can actually glue (c/a) the connector together and save pwm cables in the process.
Here is an ascii pictorial of our arrangement. only 4 cables were used instead of 11.
o|ooo|ooo|ooo|o <- sig
o             o
o             o <- ground
Hope this helps.
Phil
Unread 17-02-2005, 16:15
AKA: Dr. Brooks
no team (WRRF)
We routinely use a common ground wire for switches, but we prefer to use several "pins" for the connection. That way, if the "one and only" ground pin connection goes bad, you don't lose all of your digital input functionality.
Unread 18-02-2005, 13:24
Ageed,
With sensors being so important to your software feedback and control, this is not a place to skimp. No single point failures keep you playing.
how important is ground clearance? Zippiot Technical Discussion 10 16-02-2005 11:56
Limit Switches help. Xufer Programming 9 21-04-2004 21:21
Distro block, maxi fuse box, and ground stem ErichKeane Electrical 25 20-02-2004 07:19
Team selector switches on ISAAC Lloyd Burns Robotics Education and Curriculum 0 17-12-2002 08:32
Need help with custom switches archiver 2001 3 24-06-2002 00:35
