Go to Post FRC competitions are fun, people. If you honestly need a video game system to keep you interested, you're ignoring a tremendous experience. - Mr. Pockets [more]
Unread 17-02-2005, 21:29
Idaman323 Idaman323 is offline
In Theory, Our Robot Would Own.
FRC #1706
Team Role: Driver
Idaman323 is an unknown quantity at this point
Turning the Robot
I have one joystick programmed up to the robot, I have the p1_y's all programmed and it moves forward and backward. I have the p1_x's on pwm05 and pwm06. I have two pwm01's going to 2 victors and two pwm02's going to the other 2 victors. So where do I put the pwm05's and 06's on the victors??
Unread 17-02-2005, 23:58
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Re: Turning the Robot
You have to mix the values in the code. In the default code, pins 13-16 have a mixed signal for one joystick drive.
Look for the one joystick drive section in user_routines.c
You'll see something like
pwm13 = pwm14 = LimitMix (2000 + p1_y - p1_x + 127);
that may not be exactly it, but it will be similar. I have heard that if you use a lot of interrupts in the code, pwms 13-16 get twitchy, so you may want to change them in the code to another pwm channel. We are keeping it simple on ours, 01 for right, 02 for left, 03 for the arm motor.
Good luck
Unread 18-02-2005, 00:48
FRC #1706
Team Role: Driver
So with this code, the robot should turn? I tried this and it didn't work, I'll have to look at it tomorow i guess.
Is allowing a practice robot good for FIRST? Matt Adams General Forum 38 19-01-2005 11:35
[moderated] You write <G34> and <G35> Aidan F. Browne General Forum 109 21-04-2004 17:00
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
