Go to Post Another human taking a job that a robot could do... - Ryan Simpson [more]
Unread 18-02-2005, 14:19
cprogrammer's Avatar
cprogrammer cprogrammer is offline
FRC #1595 (Gremlins)
cprogrammer will become famous soon enoughcprogrammer will become famous soon enough
Unhappy Camera Tracking Problem
Our camera won't track with the FRC code. We have the TTL adapter on the FRC controller and we have the power, TTL port, and the servo cables plugged into the camera. When we load the code the camera won't track the color we have selected. If we could get some help that would be great.
Unread 18-02-2005, 15:00
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Camera Tracking Problem
Could you post your current code? I think you're aware that in user_routines_fast.c there's a function called User_Autonomous_Code (Pretty sure, don't quote me on it.) well in that code you want to track your color.
Everytime you call camera_track_color it will set the camera back to its home position, defeating the point of tracking. So you want to only call it once. Here's how you would do it:
int Find_Color_Flag = 0; // Initialize a flag variable
if(Find_Color_Flag == 0) // If it hasn't been called yet
     camera_find_color(GREEN); // Find the color
     Find_Color_Flag = 1; // Set the flag to true
camera_track_update(); // Track the color
That should make it track the color green.
Make sure that your camera is calibrated, and that you replaced the 3 values for the camera initialization code in the initialization function.
http://www.mikesorrenti.com/
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
Camera Tracking Woes VideoMan053 Programming 4 29-01-2005 18:09
Camera Color Recognition Problem? AnkurG Technical Discussion 3 20-01-2005 21:52
Camera Problem n_0163 Electrical 3 14-01-2005 21:10
CMUCam2 Camera Code - Are important parts commented out? Mr. Lim Programming 4 14-01-2005 12:11
