Go to Post The only dumb question is the one you don't ask. - E. Wood [more]
Unread 19-02-2005, 11:16
ten3brousone's Avatar
ten3brousone ten3brousone is offline
Kurayami o Samayou
None #1160
ten3brousone is an unknown quantity at this point
Joystick Hat button
a quick question. for the joystick hat button on top theres 4 ways you can push it. any idea what values the bot recieves when you go forward, left, down, right, on the hat button? 1, 2, 3, 4? or are they each a diff variable. thanks for help
-Rookie plz bear with me thanks!
Unread 19-02-2005, 11:22
phillutz phillutz is offline
FRC #0851 (The Froggers)
phillutz is on a distinguished road
Re: Joystick Hat button
we coded to test that out last year. Sorry just can't remember the values.
By using your dashboard or printf statments you should be able to display all the joystick values.
Phil
Unread 19-02-2005, 11:24
Kurayami o Samayou
None #1160
haha would love to but we cant find our dashboard cable ^.^ our teams not very clean haha
Unread 19-02-2005, 15:45
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Then just use printf statements like phillutz said. Edit one of the variables in the printf statement at the end of DefaultRoutine() so that is pX_wheel (X is the port number it is on)
You should see the numbers scrolling by in the terminal window after you load the program.
Unread 19-02-2005, 17:38
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
The dashboard uses a standard serial cable. There is no specialized 'dashboard' cable.
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 19-02-2005, 18:32
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
The POV hat is not wired by default. In order to use it you will have to open the joystick, disassemble the controls, test for continuity to find the POV pins, and rewire it appropriately. I just did ours today, it doesn't take very long to do (so long as you are ok at soldering). Sorry I don't have any pictures to send you, I will open the stick again if I have the time tonight.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 20-02-2005, 13:13
f00fc7c8 f00fc7c8 is offline
f00fc7c8 is an unknown quantity at this point
I tested this out the other day using the IFI Dashboard. The POV hatswitch IS wired by default, and you can read it in the variable pFOO_wheel, where FOO is the port number to which your joystick is connected.
I'm afraid I don't remember the precise values, though. Sorry.
Unread 20-02-2005, 13:22
Anton's Avatar
Anton Anton is offline
Anton Povzner
#1581 (Element)
Anton can only hope to improve
it's a variable called"pFOO_aux",where FOO is the port number to which your joystick is connected.just make a printf for it(i would have checked it myself but I don't use these joysticks).
every time you want to acess a variable and you don;t know how, go to "ifialiases.h". practically everything can be found there
Anton Povzner, head&tail of team 1581 programming team... and that's just one of the many reasons for us to loose seriously
Unread 20-02-2005, 13:31
Back after 4 years off
FRC #5279
The hat sends a pwm value
Neutral= 45
forward= 254
left = 97
down/left= 163
down= 136'=
down/right= 213
right= 203
Hope that hleps
James
Programming motors with joystick buttons TMHStitans Programming 5 21-03-2005 21:07
Joystick Button programming Bharat Nain Programming 5 18-02-2005 11:48
Joystick Button Deference cibressus53 Electrical 3 01-11-2004 09:38
Changing 1 joystick code to 2 (rookie team) Brawler006 Programming 5 20-02-2004 17:00
robot goes haywire with the one joystick default code Miles Programming 7 24-01-2003 14:58
