Go to Post What are you people going to rumor mill about if we ever actually get a water game? - Kevin Sevcik [more]
Unread 19-02-2005, 18:42
JoeFryman JoeFryman is offline
Meh.
#0094 (Technojays)
JoeFryman is an unknown quantity at this point
Send a message via AIM to JoeFryman
Speed of user_routines_fast.c
How often does user_routines_fast.c execute (as in time)??
100 gmail invites: JTFryman@gmail.com
Unread 19-02-2005, 18:48
colt527 colt527 is offline
AKA: Ken Colton
FRC #0527
colt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to beholdcolt527 is a splendid one to behold
Send a message via AIM to colt527
Re: Speed of user_routines_fast.c
Well, the autonomous section goes every 26.3ms i think.
Mentor, Team 527 -- Plainedge Red Dragons
FIRST Volunteer
SUNY Stony Brook Computer Science 2010
kcolton@gmail.com
Unread 20-02-2005, 01:09
Don Reid Don Reid is offline
Don Reid will become famous soon enough
In normal mode Process_Data_From_Local_IO() is called over and over as fast as it can be. How often it runs depends on what it does (how long that takes).
If you have access to an oscilloscope and want to measure how long your code takes, you can pulse or toggle a digital output each time through and measure it.
In autonomous mode, User_Autonomous_Code() is called once, but it has a
loop inside it which runs once every 26 ms. It exits when autonomous mode ends.
These are both called from main() in main.c.
Don Reid
speed controller max speed Team 668 Programming 15 13-02-2005 14:05
Joining 2 dif. motors K.Shaw Motors 32 14-10-2004 19:40
PID control loops - closed loop feedback KenWittlief Technical Discussion 56 26-04-2004 21:27
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
