Go to Post I get in enough trouble mentoring one team. If I did five teams I'd be less one wife. - Koko Ed [more]
Unread 20-02-2005, 01:58
Team977 Team977 is offline
Cometbots
#0977 (Cometbots)
Team Role: Webmaster
Team977 is an unknown quantity at this point
Send a message via AIM to Team977
Will the goals move
Do any of you all know how easily the goals will move. I am kind of worried that after placing a tetra on the goal, the goal might easily move, or if we run into the goal that it might move. Will they be bolted down
Unread 20-02-2005, 02:03
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: Will the goals move
They will be welcroed (if thts how its spelled) to the carpet. And beleive in the power of welcrow! Its plenty strong
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 20-02-2005, 02:28
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
Velcro?
Shift to the left, shift to the right!
Pop up, push down, byte, byte, byte!
Unread 20-02-2005, 02:50
TheMuffinMan TheMuffinMan is offline
TheMuffinMan is an unknown quantity at this point
At the skrimage I just went to, they were securely down with velcro and didn't move, and quite a few robots (including ours) hit them rather hard. I wouldn't worry about them moving too much
Unread 20-02-2005, 03:02
thoughtful's Avatar
Velcro! Thats it, *feels dumb* its just that i never saw it written down so far in my life, will try to remember now
06-Team 1219 Mentor
Unread 20-02-2005, 03:03
welcroed = welded + velcro? maybe you've got something going there haha
2005 VCU Semi-Finalists
2005 Radio Shack Innovation in Control Award
2005 Rookie Inspiration Award
Unread 20-02-2005, 03:29
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
However, at the UTC scrimmage, a robot was placing a tetra on the center goal when it's gripper became tangled between the tetra it just put on and the tetra below it, when they tried to back away I saw the center goal's base lift a little. They can take a hit, but they arent impossible to dislodge.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 20-02-2005, 04:21
NMR's Avatar
NMR NMR is offline
Heart & Soul of All Operations 696
AKA: Jianu Jr. the Sr.
FRC #0696 (Circuit Breakers)
NMR will become famous soon enough
Send a message via AIM to NMR
one of the team updates, if i am not mistaken, involved putting a plate onto the ground of the center goal which (as i understand it) is completely velcroed to the ground. When i was watching the scrimmage broadcast, I couldnt really see if they built their field like that, and even then, it barely moved.
-NMR
Consider this document signed.
Attending:
FRC Los Angeles
FRC San Diego
EAST Arkansas
Unread 20-02-2005, 05:16
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
A practice solution we've discovered - if you cut small holes in the carpet and slide a zip tie through and around each leg of a goal, it does a decent job of holding it in place. Of course, this is not a good solution for those using permanent carpet.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 20-02-2005, 12:54
Billfred's Avatar
Billfred Billfred is offline
Yep, they're velcroed down.
And it takes me (a relatively full-grown guy) a rather serious grunt to tip it on the side. A robot could do it, but a driver with the proverbial two brain cells will probably not be able to do it.
Unread 20-02-2005, 12:58
IMDWalrus's Avatar
IMDWalrus IMDWalrus is offline
This is a line...
AKA: Paul
FRC #0818 (Genesis '02)
IMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to beholdIMDWalrus is a splendid one to behold
Send a message via AIM to IMDWalrus
Why do that? If the goals aren't going to be secured that way in competition, what's the point of doing that for your practice field?
Isn't it better to let the drivers deal with exaggerated goal movement to teach them not to hit the goals at all in competition?
Unread 21-02-2005, 18:29
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Thought this might be of some iterest to those who were easily able to move the goals ...
<G20> ROBOTS may push or react against any elements of the field, provided there is no damage or disruption of the field elements. ROBOTS may not grab, grasp, grapple or attach to the GOALS or any other field structure. Robots may not extend under, lift up or tip over a GOAL. If a ROBOT violates this rule, the referee will give one warning. If the referee determines that the team is disregarding the warning, or the actions affect the outcome of the match, the team’s ROBOT will be disabled for the remainder of the match. If a GOAL is tipped over, it is automatically OWNED by the opposing alliance for the remainder of the match.
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 21-02-2005, 22:29
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Center goal has a piece of plate on the whole bottom of the base, as seen in this picture.
http://www.team237.com/gallery/UTC-S..._Medium?full=1
Side Tetra Goals, and those nearest to the players stations, have only velcro on the legs.
Unread 22-02-2005, 19:23
Tigerlily-87's Avatar
Tigerlily-87 Tigerlily-87 is offline
"1319...Smarter Than Monkeys!"
AKA: Shorty
FRC #1319 (Golden Strip Robotics)
Tigerlily-87 will become famous soon enough
Sorry man, someone beat you to it.
http://www.newscientist.com/article.ns?id=dn4986
Golden Strip Robotics Team 1319 web site
2004
Chesapeake Rookie All-Stars and Semi-Finalists
Palmetto Rookie Inspiration Award, Highest Seeded Rookie team, and Semi-Finalists
Champinships Highest Seeded Rookie Team and Curie Division Quarter-Finalists
2005
Peachtree Safety Award Winners and Semi-Finalists
2006
Boilermaker Safety Award and Spirit Award
Boilermaker Regional Winners (HUGE thanks to 1272 and 85!!!)
Mobile Goals Joshua May General Forum 12 16-03-2004 10:45
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Stategy Debate: Goals Horizontal vs Goals Vertical archiver 2001 2 23-06-2002 23:32
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
WOW ! Mike Schroeder General Forum 12 12-03-2002 21:32
