Go to Post Yes, this year's championships could be decided by cheesecake. - MrJohnston [more]
Unread 21-02-2005, 00:09
SpeakerSilenced SpeakerSilenced is offline
Programming/Electrical Team Member
#0219 (Team Impact)
SpeakerSilenced is an unknown quantity at this point
Send a message via AIM to SpeakerSilenced
OI PWM Lights blink red but still works?
It is starting to be a big concern on my team that ever since we started programming away from default code in the OI the Pwm lights hae been blinking red and sometimes green but rarely.
The controls still work fine, same with triggers... but its just weird its doing that... Any ideas?
"I want to put a ding in the universe" - Steve Jobs
Unread 21-02-2005, 00:30
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: OI PWM Lights blink red but still works?
It sounds like you have the default vision code loaded but no camera plugged in. If your not using the vision code then I don't think there is any thing in the non-vision default code that would do this unless there is a firmware level problem which sounds highly unlikely.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 21-02-2005, 01:23
whakojacko's Avatar
whakojacko whakojacko is offline
FRC #1072 (hrt)
whakojacko is on a distinguished road
Send a message via AIM to whakojacko Send a message via MSN to whakojacko
Yes that is correct. IF you are not using your camera, you can disable the camera code by going to project->build options->project and removing the _USE_CMU_CAMERA definition
Harker Robotics:1072
http://www.harker-robotics.org
Unread 21-02-2005, 03:23
Anton's Avatar
Anton Anton is offline
Anton Povzner
#1581 (Element)
Anton can only hope to improve
on the OI the lights are supposed to blink when the joystick reaches minimum/maximum/center state,at least in the 2.2 code(the one withought the camera code)
Anton Povzner, head&tail of team 1581 programming team... and that's just one of the many reasons for us to loose seriously
Unread 21-02-2005, 10:44
#0219 (Team Impact)
This is without the camera code too, they just blink red every 2 seconds, the controls still work. it might be the camera though...
Flashing Red Robot Feedback Lights zarf Programming 2 12-02-2005 16:01
Compiling Failed Teh Mike Programming 7 09-02-2005 13:27
Red lights on Operator Interface Vince lau Control System 5 01-02-2005 00:11
Yellow card / Red card usage at 2004 IRI Andy Baker Rules/Strategy 53 02-08-2004 00:35
4 pin EDU PWM out power, red pin2 V in error Dale(294engr] Electrical 4 13-02-2004 03:03
