Go to Post I always viewed Gracious Professionalism as "I may not agree with you or even like you but we need to work together to solve this problem. So let's get to work!" - Koko Ed [more]
Unread 21-02-2005, 13:19
Moloch's Avatar
Moloch Moloch is offline
Moloch can only hope to improve
Robot turning Erratically in auton...
During auton mode, when given a turn command in the commands.h, all it does is spin around in circles...please help! We ship out tonight!
Unread 21-02-2005, 17:04
Jon236's Avatar
Jon236 Jon236 is offline
AKA: Jon Mittelman
FRC #2648 (Infinite Loop)
Jon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond reputeJon236 has a reputation beyond repute
Re: Robot turning Erratically in auton...
Did you get it running with the original scripting code? I haven't been able to do that....
Jon
Unread 21-02-2005, 22:13
neilsonster's Avatar
neilsonster neilsonster is offline
AKA: Andrew Neilson
FRC #0772 (Sabre Bytes)
neilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to all
Send a message via MSN to neilsonster
Your motors are either turning in the wrong direction or your gyro isn't calculating the bias properly. For us we had to give the gyro a second to get bias or else it would spit out an angle like 20 000 milliradians to turn (it spins in circles). Try adding in some extra wait time before calculating bias. If it works then decrease it as much as you can. Hope that helps
Unread 22-02-2005, 11:33
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
the PWM's are mixed up. swap them and it will solve your problems.
Unread 23-02-2005, 13:49
Moloch's Avatar
Incorrect.
Unread 23-02-2005, 14:20
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Incorrect.
I'm not sure who you're saying was incorrect, but turning one of the cables around would definetly solve your problem, but it's most likely not the solution you want. (Because you, I assume, have it working correctly under normal driver control.)
What I would do is go into pid.c and and find the function called pid(). Down at the bottom of that function, find these lines:
switch (motor)
  case LEFT:
    wheel_l = (unsigned char)(PWM_ZERO + LEFT_DIR * motor_info[left].pwm);
	break;
  case RIGHT:
    wheel_r = (unsigned char)(PWM_ZERO + RIGHT_DIR * motor_info[right].pwm);
	break;
  default:
	printf("Unknown motor");
	break;
For which ever motor is running the wrong way, take the value they are currently assigning to it and subtract it from 255. IE, if you're left motor is the one running backward:
switch (motor)
  case LEFT:
    wheel_l = 255 - (unsigned char)(PWM_ZERO + LEFT_DIR * motor_info[left].pwm);
	break;
  case RIGHT:
	break;
  default:
	break;
Yep... and I just read your post and discovered that it spins in circles when you tell it to turn. So I'll leave that because it may help someone else, but now for my new answer:
You're probably going so fast that your encoders are missing clicks. If you're not using interrupts, you have a fairly limited ability to see state changes...
Unread 23-02-2005, 16:07
I would assume that your encoders are working, since you didn't mention any problems with going straight. Is your gyro working is the first question.
Even with a working gyro, we had trouble with the turning code, I think it was because our encoders didn't give enough resolution to give good velocity control. With a few modifications we were able to get the code to turn with encoders working well enough. We're still working on turning with the gyro.
Winning Robot or Quality Robot? Eric Bareiss General Forum 30 09-02-2006 13:19
Is allowing a practice robot good for FIRST? Matt Adams General Forum 38 19-01-2005 11:35
[moderated] You write <G34> and <G35> Aidan F. Browne General Forum 109 21-04-2004 17:00
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
