Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
View Poll Results: You can locate the vision tetra and you...
... used Auto Servo Mode 8 50.00%
... didn't use Auto Servo Mode 8 50.00%
Voters: 16. You may not vote on this poll
Unread 23-02-2005, 18:54
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Did you use Auto Servo Mode?
For teams that can locate (not necesarily cap) the vision tetra:
Did you use auto servo mode or did you manually pan the camera?
177 decided that it was too likely that the camera would not start with a vision tetra in its field of vision and so we don't use auto servo mode at all. All of the camera turning is done completely manually by the RC.
What did you guys find works best for you?
Unread 23-02-2005, 19:31
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Did you use Auto Servo Mode?
I'm using auto servo mode, but I'd prefer not to. Is there any chance that you could share your algorithm for manual searching?
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 23-02-2005, 22:17
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
When we were looking into using the camera, we decided on algorithm which used both manual searching and autoservo. Autoservo works very well when the tetra is in view.
Matt
Unread 24-02-2005, 00:32
I was considering rewriting the code to use auto-servo mode, but I figure since we already have it working without auto-servo mode... Since the camera only really covers about 35 degrees, we didn't think we could count on the tetra being in view enough of the time.
Unread 24-02-2005, 01:45
The basic gist of it is that you use a manual mode to execute a search pattern for the tetra. When you find it, you switch to autoservo mode. If you lose it, you go back to the search pattern. It's fairly simple and worked rather well for us. The autoservo mode is quite good and provides a really easy way of working with the camera.
That said, we dropped the camera when we realized that we wouldn't have enough time in autonomous to find and cap with it (that whole falling over thing doesn't help much).
Matt
Unread 24-02-2005, 03:03
Auto Servo Mode serves it purpose quite well. We used a basic counter loop that incremented the position of the pan servo and when we got a good T-Packet we swapped it over to auto track mode.
Unread 03-03-2005, 02:20
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
My one attempt at writing my own servo control ended when I got annoyed with the compiler over a stupid error. Later I figured out what the error was, but I didnt have time to fix it, and anyway I had working code using autoservo and just turning the whole robot to scan the field. It works really well (except for being disabled before autonomous and thus wasting time) but we still probably wont use our camera as I never did get around to testing our autonomous program.
Unread 27-04-2005, 01:15
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Sorry to bring up an old thread, but this intrigues me. We tried doing the same but every time we enabled auto_servo_mode it would reset to 127, 127 and lose the color tracking settings.
Matt Krass
Unread 27-04-2005, 15:35
Precisely why we didn't use it.
Auto mode help..... Moloch Programming 2 18-02-2005 09:18
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
