Go to Post I think it's pretty cool that the Black Eyed Peas and other celebrities are willing to take up their time to come celebrate science and technology with us. - BIGWILLI2081 [more]
Unread 25-02-2005, 21:06
ten3brousone's Avatar
ten3brousone ten3brousone is offline
Kurayami o Samayou
None #1160
ten3brousone is an unknown quantity at this point
Wiring Banner sensors
ok part programming/electrical question here
right now this is how our banner sensor (the line tracker from 2 years ago) is wired up, our first time doing it to so please excuse the mistakes if there are any
Banner sensor is connected to the white wire of the pwm able
the brown cable goes to the breaker board
the black goes to the ground
and the pwm cable end where you plug into control board, WRB, the RB are not in use
not sure if this is how we wire it?
W R B
B br w B=black br=brown w=white
| | to banner sensor
| to breaker
|__to ground
ok programming problem is our digital_oc_input (or whatever variable is, dont have reference guide with me sorry) is always 1, is it because our white line (alternating black and white lines on label paper stuck to a piece of paper then glued onto wheel) isnt reflective enough or is the range too close, ithink...about 3 inches away from the banner sensor
any help would be appreciated thanks
-Rookie plz bear with me thanks!
Unread 25-02-2005, 21:37
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Re: Wiring Banner sensors
There's no blue wire on your sensor? The correct connection for the banner sensors from 2003 is:
brown wire (+12V) is connected to a 20A breaker on the breaker panel
blue wire - ground on breaker panel (not the RC)
The signal can be configured one of two ways. If the black wire on the sensor is connected to the digital input Signal pin (White PWM wire), the default value is 0 (open). If the white wire on the sensor is connected to the signal pin, the value read will be 1 (closed).
You probably need to adjust the gain on the sensor. There is a little variable resistor on the side of the sensor that can be adjusted with a screwdriver. Use the light on the sensor to figure out if the sensor is reading the wheel correctly. If the light is on it is seeing a white. If it is off it is seeing black. If the light doesn't change when you move the wheel, adjust the gain on the sensor.
Adjusting the sensors is a a guess-and-check process. This will most likely solve your problem, although you may have it wired incorrectly. Check the wiring as I described above.
Unread 25-02-2005, 22:35
Kurayami o Samayou
None #1160
sorry yeah the black i had was blue sorry, i had a B on my pencil diagram and didnt post about it till couple days later so i assumed it was black. mm and the light you were refering to, we have it close by default so when it hits white lines it should be 0? and the light you were refering to its the actual red light that emits from the banner sensor or is it on the side of the sensor
Unread 26-02-2005, 01:02
Kurayami o Samayou
None #1160
btw is white from normal printing paper enough to be recognized or does it need to be something like white electrical tape or reflective tape?
Unread 26-02-2005, 01:25
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
yup its pretty much any white, my team use white out to produce white whch works well and black can be almost naythign too like electircal tape or a sharppee or black plastic of your wheels.
if your concerned tho about your white and black u have that lil adjustment in and that should be able to help u find the balance between the two and also will help u if distance of the sensor is an issue.
-Osc-
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 26-02-2005, 01:31
Kurayami o Samayou
None #1160
Originally Posted by SpaceOsc
yup its pretty much any white, my team use white up to produce white whch works well and black can be almost naythign too like electircal tape or a sharppee or black plastic of your wheels.
-Osc-
alright thanks alot
Unread 01-03-2005, 20:03
Justin_302's Avatar
Justin_302 Justin_302 is offline
Justin
AKA: Justin
FRC #0302 (Mechanical Dragons)
Team Role: Driver
Justin_302 is on a distinguished road
Send a message via AIM to Justin_302
is the item you are sensing a wheel?
and all three wires go directly to the computer. use the white wire.
Team 302
Wiring Banner Sensors ten3brousone Electrical 1 17-02-2005 03:16
Banner Sensors Padfoot Black Electrical 6 06-04-2004 10:06
Current sensors wiring zainali Electrical 5 13-02-2004 00:39
wiring diagram for light sensors??? pagemauck Control System 1 21-01-2004 16:32
banner sensors edomus General Forum 7 20-11-2003 19:43
