pic: West Coast Collaborationz and Team 254 Present
Re: pic: West Coast Collaborationz and Team 254 Present
You are using the same robot at last year?
Could you please tell/show the differences? ..It looks amazing. Last edited by Tom Bottiglieri : 26-02-2005 at 19:02. |
hmm... it looks ALMOST the same... here is a picture of team 60's robot last year which was a clone of 254. looks like everything is same but the claw.
... What I like about it is, they know they have something that works, they just perfected it more. |
They now have a hard pole to knock down the tetras instead of the flexible rod they had to knock off the 10 point balls
from what i see... there is one more joint to the arm... same DT from show... and the gripper is diffrent... other than that it looks the same...
great job in the improvements... |
It's almost the same 'bot as last year's, with some changes:
-Totally redesigned drivetrain - we're using 2 fisher price's (with the andymark transmissions) and 2 atwoods to run it, and we can shift on the fly. Also, the gearboxes are almost 50% lighter than last year's. -Yes, the arm has 3 joints, but the top joint is chained to the lower part of the arm, so that it always moves parallel to it. -We machined gearboxes to run the arm as well, because we were having problems with the plastic gearboxes on the fisher price motors from last year. -The arm is run by 2 atwoods, not 2 FP's and and a van door. There are a few minor tweaks here and there, but those are the main differences. |
#7
"if it ain't broke, don't fix it..."
After a typically successful 2004 season, it looks Team 254 made the decision to stick with what works. At this year's kickoff I predicted that many of the top 2004 teams would only make slight changes to their robots and modify their end effectors to pick up tetras. Team 254 is a perfect example of this phenomena. Considering the similarities to their 2004 robot, I'm sure this version was completed pretty early in the build, allowing for more practice and tweaking. A good robot, heavily tweaked with practiced drivers usually goes very far. Great work. Can't wait to see it in Atlanta. |
#8
At least we've got the practice robot to play with until Sacramento. |
#9
Awesome looking robot. Last year, your robot was my favorite - it did everything and it did it so well.
I went to your website (as the caption suggested) and I found that the robot's weight is 129lbs. Is that with or without the battery? When we weighed our robot with the battery, it was somewhere between 132 and 133lbs. |
#10
how many teams are meber of the West Coast Collaborationz?? Just you and 60, or are there more this year?
#11
Very nice!
Though I am a bit scared at the idea that a game suppose to be "rookie friendly" and a game that can be played with an almost-last-year's robot are suppose to be the same thing. |
#12
I dont think 60 is collaborating with 254 this year. But i might be wrong.
#13
