Go to Post Ship day is a sweet and sour day. You're happy to see your robot ship, but then you start going through robot withdrawl - Schneidie [more]
Unread 27-02-2005, 01:49
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
How to calculate planetary gear ratios?
At one time or another I knew how to do this but it has been a while.
What is the formula for a planeatary gear ratio involving the tooth counts on sun, planet, and ring gears assuming the ring gear is held stationary?
Thanks.
EDIT: I looked a little harder and found it to be (sun+ring)/(sun).
Unread 27-02-2005, 09:38
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: How to calculate planetary gear ratios?
While this was mentioned, does anyone know any good websites that tell you how to do this?
This is one thing I would like to know how to do!
I could probably google it, but there are probably a million websites that are not what I need.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 27-02-2005, 11:55
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Have you had a chance to read the white paper by Paul Copioli, here, it covers very well planetary systems and of course dual motor planetaries also. There's also a good pdf written by Martin L. Culpepper, here which helps a lot. Good luck
Efficent number of Gear ratios... Matt Attallah Kit & Additional Hardware 12 14-09-2004 10:42
gear ratios roboteer49 Motors 22 29-04-2004 20:51
Reverse Gear FizMan Technical Discussion 12 26-04-2004 01:29
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
