Go to Post Thankfully, no magic smoke was released during the making of these photos. - SteveGarward [more]
Unread 28-02-2005, 11:20
gacp gacp is offline
AKA: Gilbert A. Castillo
#0928 (Secme)
gacp is an unknown quantity at this point
Autonomous Code (Help!!!)
I would like anyone who is good at programing to help me write a piece of code: For the autonomous mode, our robot has to move forward for, lets say 5 seconds at full speed. turn on relay 5, and then turn on relay 4. Then, the robot should go back for 2 second. could anybody help.
Unread 28-02-2005, 11:47
Re: Autonomous Code (Help!!!)
Sure, I'll help.
Start by using a simple counter inside the autonomous mode communication loop. Set it to zero as soon as you enter the autonomous_mode function. Whenever you get new data, increment its value. That will happen about every 26 milliseconds, so 38 counts is very close to a second.
Then test the value of the counter after you increment it. If it's between 0 and 5*38, you're in the first five seconds, so you turn the drive motors on full forward. If it's between 5*38 and 7*38, you're in the next two seconds, so you activate the relays and turn the drive motors on in reverse. If it's greater than 7*38, turn off the drive motors.
That will do what you asked. You can get more detailed with timing of the relays if you wish, or you can add more steps with more actions.
For what it's worth, I'd expect most robots going five seconds at full speed this year will run into one of the mid-field goals. Some will likely be fast enough to run into the far goals if they manage to miss the mid-field ones -- assuming they also don't ram the opposing alliance's robots.
Unread 28-02-2005, 11:49
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
You could do something like this
in user_routines_fast
timer++;
if(timer<300)
pwm11=255;
pwm12=0;
else if(timer<310)
relay4_fwd=1;
else if(timer<320)
relay5_fwd=1;
relay4_fwd=0;
else if(timer<440)
pwm12=255;
pwm11=0;
BUT, you'll probably have to change the pwm's around to make it go forward. Also, you never said if you wanted the relays on fwd or rev. Also, all the times are only approximate, and relay4_fwd is only on for 1/6 of a second and relay5_fwd stays on forever, once relay4_fwd turns off. Hope that helps or gets you started.
Also, i just used arbitrarily 60 cycles as one second, which is wrong, so don't trust that.
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Unread 28-02-2005, 12:59
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
timer++;
if(timer<300)
pwm11=255;
pwm12=0;
else if(timer<310)
relay4_fwd=1;
else if(timer<320)
relay5_fwd=1;
relay4_fwd=0;
else if(timer<440)
pwm12=255;
pwm11=0;
Beware the 255! You shouldn't set the PWM to 255, the maximum value is 254. The radio packets are framed with 255 and if you use a value of 255 you'll mess up the communication. Other than that the code looks like it should do what you want.
- Gene Falendysz
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
InfraRed autonomous code ... mtrawls Programming 1 11-01-2004 00:25
