how many vandoors?
We were reading over the first rules and had a question. According to first, you can use what is provided in the kit. From the way it sounds, we can use 2 vandoor motors because on the list of parts, it list the quanity as 2. We checked an update though that says you can use only one vandoor motor which is a problem because our robot has 2. Can someone help clairify this a little more?
Re: how many vandoors?
1!
If you have two on your robot, you'll need to remove one to pass inspection. |
We recieved two in our kit and designed our robot around that. When we noticed the update, we had to redesign our spool to be powered by two fisher prices instead. Ironically this is what made it possible for us to get underweight so we're not complaining. I was confused about that too though.... Did FIRST intend to give two, but then realized they didn't send all teams 2? Or did they accidently send 2? It seems conspicuous that some teams got 2 motors, AND it was listed as 2 in the begining. Any thoughts?
i dont know, but we got 2 and designed our bot for 2.....looks like we have redesigning to do at the comp.
Keep the other one for a spare, but definately redesigning is in order.
#7
Team Update 1 "Corrections to Kit of Parts quantities... Taigene – The quantity should be 1, not 2." |
#8
first is just like john kerry......always flip floping rules....it angers me
#9
as for the matter of the Van door problem, we used a window motor in addition to the Van door, its not as powerful but it is a similar shape and would probably be the easiest replacement to install. |
