Ask about intergration
As we know, if we intergrate the angular rate we'll get the angular. That's why we can use MEMS gyro to measure angular. I'm now using ADXRS150 gyro. But I don't what intergration hardware (what chip or processor) can do this (intergral). Can any one tell me a bit detail about this plz!
Re: Ask about intergration
you just need gyro.c and gyro.h from his navigation software. It will work with the 150. hint:use kevin's code. I tried to use the 150 last year to get a heading, but it didn't work very well. Kevin's stuff is a lot easier. |
As I understand what's going on in Keven's code it's like this. The process takes over the A/D, and at regular (that's the key) intervals reads the gyro chip and adds or subtracts from an accumulator. From there you can get heading. This may be a large over simplification and is a I understand the process, Kevin really has the skinny on how it works. I suggest you read his read me, notes on the process.
I have now gyro.c and gyro.h (and all navigation.zip too!) but can you tell me what software and hardware I have to take to make it work?
All I have now: ADXRS150, uC: ATMEGA8535 with 10bit ADC, superior loader to load program into uC. I also have a software which I wrote in Turbo C and it can receive data from ADXRS150 gyro through ADC of uC. It can measure voltage by software very exactly but when I change to angular it not exactly: real 10 degree but value in software only :9.89 real 20 degree but value in software only :14.5 real 30 degree but value in software only :20.3 May be it cause of intergration in my software. I didn't measure the interval between a sample and the next exactly. So I want to try another method as Kevin use here. And again, I want to know what software, hardware I need to have and what to do next? |
www.srvhsrobotics.org -> Articles -> Technical Documents -> C Programming for the Robot Controller Have fun. Done forget to read the gyro at startup to set the "old" value, or you will have a bogus value for the integral on startup. |
| "stratagy" angers me deeply... | Zeinin | General Forum | 12 | 12-01-2002 22:33 |
