question about solid works
If I measure an angle and it read something like 61.5 degrees, how do I go about changine it to 60?
Re: question about solid works
You have to dimension the angle, not just measure it. Also, you can only change dimensions in sketches. So first you should open up the sketch that pertains to whatever angle you're looking at. Dimension that angle, and then double click on the value to change it. If you get a message about overconstraining the sketch, it means you've added too many dimensions and they're inconsistent in some way. So then you need to delete a dimension you don't care about.
| An ethical question | _GP_ | General Forum | 45 | 18-03-2004 19:36 |
| MIM's question of the day on programming. | Gene F | Programming | 3 | 24-02-2004 16:32 |
| A question about control system options | computhief263 | Control System | 7 | 04-02-2004 14:46 |
| my idea of a question forum... | Ken Leung | General Forum | 12 | 30-11-2002 12:17 |
