IFI motor problem
we are trying to figure out what the IFI Multi-Speed Motor wires mean the black red yellow orange wires
we want to know if anybody knows what they are thanks sebas go TechTigers 1251 |
Re: IFI motor problem
Please be more specific... Are you talking about the Edubot servos? Regards, Mike |
I think he's talking about these motors
The black red yellow orange wire is the only means to control & power the motor. The EDUBot Controller has special ports for these motors, although you can directly plug the motors into pwm ports and relay ports (they autodetect the port-type) on the FRC Robot Controller. |
That seemed pretty specific to me. It is no longer called the Edubot and they are not servos. This is what he is talking about http://www.ifirobotics.com/edu-motors.shtml
Typically servos (which these are not) have three wires: positve, ground, and signal. What the 4th is for here, I don't know. |
yes we are sebas |
what we need to know is what the orange wire is four because we are trying adapt it to a bobot
sebas |
#7
The IFI multi-speed motor, which I believe is what you were talking about, is the one with the 4 wired cable (Black, Red, Yellow, Orange). IFI doesn't make servos.
Regardless, I think you're looking for this: Black - Ground Red - +Battery Yellow - PWM Control Orange - +Battery Here's the document on the 2004 Mini Robot Controller, look on Page 8, there's the pin-out diagram for the multi-speed motor. Last edited by NoodleKnight : 22-03-2005 at 22:35. Reason: found documents |
#8
sebas |
#9
That's odd, I wonder why there are two power + ?
Anyway, why would you adapt this to a BoeBot instead of just using the modified servos that come with it? http://www.parallax.com/detail.asp?product_id=900-00008 Very cheap too. The speed and torque are comparable as well. |
| Building an arena controller | CJO | Control System | 32 | 29-03-2005 07:04 |
| IFI Loader and PROG button | Dave... | Programming | 3 | 20-02-2005 12:03 |
| IFI Loader usually hangs midway thru load | gnormhurst | Programming | 4 | 04-02-2004 11:40 |
| IFI Loader Problems | BrendaB | Programming | 3 | 24-01-2004 22:45 |
| Bug in IFI Loader | rwaliany | Programming | 2 | 06-01-2004 21:26 |
