Cylinder weights
I'm doing some mental math in my head, and debating what my team could do with the three pounds we have left. Does anyone know weights of cylinders? Most specifically, I'm looking for a 2" stroke 3/4" bore. Also interested in the weight of a 2" stroke 1 1/2" bore.
Re: Cylinder weights
This should help: http://www.chiefdelphi.com/forums/sh...ad.php?t=33293
go to the bimba site (I think www.bimba.com) - you can download the catalog - or specific parts.
One hint, though, they give a base weight, and then an increment per inch of stroke. You have to do some calculating. |
I found some 3" stroke pneumatics which will work, they weight about .36 lbs each. The pneumatics manual does have a nice list of approximate weights. Thanks.
| Mulit-postioning with pnuematics this year? | KenWittlief | Pneumatics | 101 | 01-02-2005 21:54 |
| Making a series of spaced holes around a cylinder in inventor | James114 | Inventor | 13 | 21-11-2004 18:44 |
| Need Inventor model 3/4" Bore Cylinder Quick | sanddrag | Inventor | 1 | 05-04-2004 00:40 |
| Is 'using a smaller cylinder' really that easy?? | mjt902 | Pneumatics | 4 | 29-01-2003 16:13 |
| Stopping a Piston... | Dan 550 | Technical Discussion | 7 | 02-02-2002 11:36 |
