this year ohm bots mounted computer neon tubes under our robot and were able to control them from the control station (ironically this was the most reliable aspect on our robot). well this year I'm looking to go one step farther. since we also used nylon mesh tubing to organize all our wiring (highly recommended for neatness but find a way to mark wires first!) I'm going to run something called EL wire through all our tubing. imagine you flip a switch and all your beautiful wiring glows... very cool. Ive also found a LCD board that does the sequential flashing as seen on night rider or the cylons on battle star galactica. just some ideas. if anyone has any other cool ideas post them.
Re: oooh purty
I was considering suggesting making use of automotive clearance lights (roughly $2 at Auto Zone) for some approximately pimped-out decoration, but it became obvious that we were having trouble making weight as it was, so I kept my mouth shut. (You have no idea how many mounting panels we went through to make weight.)
Re: oooh purty
Well, how about this, mechanicalbrain: instead of just for looks, use it for some diagnostics, too. If you plan to use connectors, then hook the EL lights (people in case mod circles love that stuff!) into the same connectors as the wires. That way, if a connector fails, the light will fail at that point, and you can easily tell where the power ends.
Just a thought. Sparks |
Re: oooh purty
well i like that idea but dont you need converter to run them and that would mean i need one for every connector
also i would hate to have one fail and spend hours searching a robot for problems just to find out its the lights. |
Re: oooh purty
Re: oooh purty
Do they need converters? I didn't know that. It was just an idea, anyway, plus I think jdiwnab has a good one there. I was considering using LED's at the connector itself for the same purpose, but saw this idea, and thought: hey, why not give it some bling?
Sparks |
#7
Re: oooh purty
Just an idea, but sometime ago I wrote some example code that showed how to vary the light output of an LED using the PIC18F8520's built-in PWM hardware. This code could be used with last year's IR beacon circuit to drive an array of tri-color high-brightness LEDs to create a pretty wide color spectrum. The filename is edu_led_pwm.zip and it's located here: http://kevin.org/frc.
-Kevin |
#8
Re: oooh purty
I made a simple one of these for my car's front end. I can send you a schematic if you want. It cost me around $10.00 from Radio-shack.
![]() Knight-Rider all the way. |
#9
Re: oooh purty
121 had some nifty colored wire on our bot this year. We spelled out "121" on the sides in red and blue glow wire, and then we would switch between turning the red or blue on and off depending on what alliance we were on.
It was pretty cool. ![]() Dave |
#10
Re: oooh purty
Wetzel |
#11
Re: oooh purty
Re: oooh purty
Re: oooh purty
Re: oooh purty
Re: oooh purty
with any equipement that has a radio receiver, and analog inputs running on long wires, you need to be very carefull what type of other equipment you install, esp something that runs on high voltages. I would not recommend running light tubes side by side with any control wires running through your robot chassis - the PWM wires for example - that would be begging for problems. |
| CMUcam II and competition lighting environments | dlavery | Programming | 5 | 16-02-2005 02:07 |
| Off season projects | JamesCH95 | General Forum | 17 | 13-12-2004 23:32 |
| Sub Forum suggestion. (Non Robot) Team building projects. | Elgin Clock | CD Forum Support | 3 | 03-12-2004 14:30 |
| Night scene lighting | Lev | 3D Animation and Competition | 14 | 30-01-2003 23:43 |
