Go to Post There are no simple solutions, as every solution has its own problems. - M. Lillis [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 24-06-2005, 13:02
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Font server?
Um... how would one go about setting up a [Linux X Winders] font server? This would be on Ubuntu (Hoary), if changes things too much.
Optionally (preferably), does anyone know how to start Cygwin's XFree86 with a local font path specified with the "fp" option? It has to not rely on the registry keys Cygwin uses by default.
And because I know someone will ask, I'm trying to cut Cygwin down to the bare-minimum which will still login (through XDMCP) to my Ubuntu server. Right now it's at 47MB, with more stripping available, I'm sure, but I'm stuck on getting it to load the appropriate fonts, so that doesn't do me much good.
Unread 24-06-2005, 15:20
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
Re: Font server?
I've never had to set up an X font server before but you may be able to simply share the X Font directory through SFTP or Samba or something and them mount it in Cygwin's X font directory becuase I believe this is basicly what the X font server does only in a much more effiecent manner. I will see if I can test the set up I described.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
Unread 24-06-2005, 20:45
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Re: Font server?
If you're trying to use xfstt, I know you can comment out no-listen = tcp in (generally) /etc/X11/xfs/config. That should let it run on port 7100/tcp (maybe 7101 because that's what debian uses.) Make sure you firewall that off from non-local connections.
Also, I don't know anything about CYGWIN, but xset fp+ /path/ should set the font path. Maybe that's of no use, but like I said, never touched CYGWIN. Do you still have an XF86Config-4 file? If so, just stick
Section "Files"
    FontPath   "/font/path/"
EndSection
in it. Sorry if any (all?) of this was useless
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
E-Mail Server Venkatesh IT / Communications 15 27-06-2005 01:47
Server Load Brandon Martus Announcements 10 27-04-2005 20:25
Home DNS Server? sanddrag IT / Communications 14 08-03-2005 02:09
projectpoint server problems MSBlaster Inventor 1 11-01-2005 13:37
IRC Server LBK Rules Website Design/Showcase 9 15-11-2004 19:41
