Go to Post Think, Write, Re-Think, Erase or Post - and Deal With it Either Way. - Chris Fultz [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 24-06-2005, 19:15
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
AJAX
I just discovered this, and I love it. Anybody else use it?
http://www.mikesorrenti.com/
Unread 24-06-2005, 20:30
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Re: AJAX
Oh yeah, AJAX totally rocks. Hardest part about it is that whole cross-compatability stuff with other browsers and such. It's wonderful if you're using it for personal projects (which is what I do with it). It can make everything seem so seamless!
If anyone is wondering, straight out of wikipedia:
AJAX or Asynchronous JavaScript and XML is a term describing a web development technique for creating interactive web applications using a combination of:
HTML (or XHTML) and Cascading Style Sheets for presenting information
Document Object Model, JavaScript to dynamically display and interact with the information presented
XML, XSLT and the XMLHttpRequest object to interchange and manipulate data asynchronously with the web server (although AJAX applications can use other technologies, including preformatted HTML, plain text, JSON and JSON-RPC as alternatives to XML/XSLT).
Basically you use javascript as the link between the client and the server. You use XMLHttpRequest to grab XML from a server and parse it again with javascript. Excellent examples of AJAX in use are GMail and Google Maps. It's also been showing up recently for blogs, forums, and online chats, to make things seem more integrated by not constantly refreshing the browser.
Some good reading, if you're interested, is:
http://developer.apple.com/internet/...mlhttpreq.html
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 25-06-2005, 11:55
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Re: AJAX
CD-Media .. when the first page loads up and it says "loading..." and then the papers & photos pop up. Thats Ajax.
There will be much more, once I get going on that again.
The one thing I've been reading over & over -- don't over-do it. It's nice to have, but you can go overboard and really mess up your UI.
Brandon Martus
e-mail
Unread 26-06-2005, 21:14
Mike's Avatar
AKA: Mike Sorrenti
Re: AJAX
That is true. In any project that uses a not 100% supported technology, make sure theres an alternative. I just add a link to a normal PHP form, that uses POST, this way the user with Javascript disabled can still use my application.
