If you could write the default code...
Just out of curiosity, if you could design the RC default code, what would the architecture look like? What do you like about the current default RC code? What don't you like?
-Kevin |
Re: If you could write the default code...
I think functions names could be shortened, with explanatory comments. I know (well, I don't know but I suspect very strongly) you are trying to make the function names self-explanatory, but after a while it gets annoying to be perfectly honest typing out those long names. And maybe make the flow a little bit easier to follow, otherwise I commend your work, it's quite helpful.
-Kevin |
Maybe a more logical flow (altho im not sure what, but you asked for feedback), so you don't have to go hunting through every file for that function! Personally i dont mind the long names - i'd rather them than, 'what does this do again?!' ~Stephanie Team 1351 ps- i'll think about what to change next time im programming! ![]() [edit] and i definately agree w/ seanwitte, see below [/edit] Last edited by RbtGal1351 : 01-07-2005 at 22:43. |
It would be nice if was organized with hooks for discrete events since the programs all follow a similar lifecycle. This is rough, but something like:
masterSystemInit() - runs once at startup to configure the device masterUserInit() - runs once at startup to configure user information runDisabled() - runs while robot is disabled initAutonomous() - runs once when state changes to autonomous runAutonomous() - runs each cycle during autonomous initTeleoperation() - runs once when state changes to teleoperation mode runTeleoperation() - runs each cycle during teleoperation readInputs() - runs at the start of each cycle to collect any inputs writeOutputs() - runs at the end of each cycle to update relays and motors This framework would allow you to focus on these relatively simple stubs. The flow of the framework code would be something like: masterSystemInit() masterUserInit() while 1=1 wait for master uP readInputs() if runState != previous runState then if runState = AUTO then initAutonomous() elseif runState = TELEOP then initTeleoperation() end if if runState = DISABLED then runDisabled() else if runState = AUTO then runAutonomous() else runTeleoperation() end if writeOutputs() wend |
![]() Two things: I can't stand the fact that spaces are used instead of tabs ( ) and it might be nice (especially for new FIRST programmers) if all "never editable" files were moved into a subdirectory. That would make it more obvious what you are supposed to edit as well as make finding individual files easier.Last edited by Ryan M. : 02-07-2005 at 13:37. |
#7
-Kevin |
#8
I personally like being able to modify main.c, and I think that "DO NOT EDIT THIS FILE" should be sufficient warning for the clueless.
I like how the code is put together to some extent, but I sometimes wish it weren't so massively splayed out across 15 files. |
#10
I just hate how they made all those 'don't touch' read only. What if I want to add my own aliases to ifi_aliases.h? I have to go out of MPLAB, find the file, un-read-only it, and then re-open it with MPLAB.
#11
Yeah, I know, I removed read-only from everything as soon as I got the default code, but it's still annoying.
#13
Instead, you should create a new file, perhaps "kyles_aliases.h" and add everything you want there. |
#14
I was new to the code this year, and noticed that the basic architecture is scan loops and ISR's.
Would it be useful to have an advanced version of the default code that contained an RTOS (Real Time Operating System). With an RTOS the application code could be designed as indepently executing threads. I know it would add a layer of complexity as the programmers of this type of code kit would need to understand: - what a semaphore is - task priorities, and priority inversion - designing and debugging multi-threaded code - concepts like task switching, mutual exclusion, and race conditions - Memory management - Stack allocation, and management a lot of complex things to understand, but a lot to be gained also, which is why I was thinking in terms of offering this as a optional "advanced" code kit. I have always been very comfortable working with real-time embedded code, and RTOS's. But it is an area of interest for me But I am wondering what others think of this??? Is an RTOS to far out, and complex to be used in a FIRST Robot ? --Mike O'Brien |
#15
I feel it's not entirely necessary at this point... Not to mention I doubt it's feasible with the current controller (think about the tiny memory size). That being said, if something more simplistic were done such as a simple cooperative multitasker (that's part of my design for next year), that would definitely be good. At the moment though, debugging is painful enough on the RC - no need to throw multithreading into the mix .OP: I think maybe having cleaner code in general... No functions with comment headers longer than the functions, consistent naming, things like that. |
| Out of the Box Camera Code | russell | Programming | 9 | 21-10-2009 05:28 |
| Best Way To Insert Autonomous Code Into Default then load help.? :-)? | gemccnp | Programming | 2 | 05-02-2005 18:58 |
| default code vs. 2.4 | stephenthe1 | Programming | 2 | 05-02-2005 18:02 |
| Team THRUST - Kevin's Code and Camera Code Combine | Chris_Elston | Programming | 3 | 31-01-2005 22:28 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
