Go to Post We can help make those dreams, maybe. ;) - Adare180 [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 07-07-2005, 14:38
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Formatted textareas
How do you format individual portions of text in a textarea? IE, like Gmail or this thingy does.
Unread 07-07-2005, 14:42
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Formatted textareas
It's called a WYSIWYG (What You See Is What You Get) editor.
http://www.google.com/search?q=%22WYSIWYG%20Editor%22
That search should give you a ton of results.
http://www.mikesorrenti.com/
Unread 07-07-2005, 14:46
Programming User
But how is it actually done? What HTML/CSS combo actually allows you to change the formatting in the box?
If I had
<textarea>a b c d e f g</textarea>
and I wanted to make "c" bold, how could I do it? Just assumed it's static for now, don't worry about JS (for now ). I just need the static HTML.
Unread 07-07-2005, 16:13
Randy Randy is offline
Randy will become famous soon enough
This site uses DHTMLEditor, which you can view the source to through OpenFirst (http://www.openfirst.org or http://openfirst.sourceforge.net).
FREE WEB HOSTING for FIRST teams and related organizations.
  • Team sites
  • Image Hosting
  • Video Hosting
Email promo@sevaa.com or click here for details.
Unread 07-07-2005, 18:54
Timothy D. Ginn's Avatar
Timothy D. Ginn Timothy D. Ginn is offline
I check here maybe once a year.
Timothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to allTimothy D. Ginn is a name known to all
Send a message via ICQ to Timothy D. Ginn Send a message via AIM to Timothy D. Ginn Send a message via MSN to Timothy D. Ginn Send a message via Yahoo to Timothy D. Ginn
See also:
http://www.chiefdelphi.com/forums/sh...010#post394010
(and the PM that I sent you this morning with much of the same information). It's kind of weird to be answering questions via PM before they're asked, lol.
Alumni of FRC Team 1006
Former mentor of Full Lego Alchemist (FLL 5621) - Sempar School / Computing Students' Association of Queen's University
Unread 07-07-2005, 19:19
Programming User
Originally Posted by Timothy D. Ginn
See also:
Yep. I was hoping for a simple "oh, you just stick this attribute in" type thing, so I wouldn't have to dig through all that stuff.
I did find out how it's done (Mozilla has a nice page), and started some work (well, you can type stuff) at http://traherom.homeunix.net/editor/js.html. It's kinda plain because I was just using it as testing...
I'm thinking about doing something along the lines of this (click to edit part of the page. Or maybe I could do it as select the text you want to edit then press a key), but add rich editing instead of just the plain textarea.
Unread 07-07-2005, 19:29
That would be nice (just having to set a single attribute); actually, though, the one I suggested in the edit I made to the thread mentioned above will go through every textarea (or other element that you choose) and convert it to be fancy automatically. It also doesn't require mucking around with setting Javascript things up on each of the forms you want to use for onclick, etc. I'm actually surprised that it's so transparent. (If you download it and look at the simple demo, which has a lot less HTML, etc. confusing things, it becomes obvious how things work, and easy to move up to the advanced one).
