Old 883= 24V Speed controller???
We are working on building a cart to move our robot around. It will be powered, and we found some 24V motors off an old robot for a different competition that we can use, but we don't have any speed controllers. On the Innovation First website the old victor 883 is listed as a 24v model. Could it be that the old 883's could handle 24V and that is why first switched to the 12V 884's? Just wondering if anyone knows whether or not the victor 883 speed controllers supplied in previous years can handle 24V. Thanks
Re: Old 883= 24V Speed controller???
It's been a while, so I may be wrong on this, but I seem to remember that IFI made both 12V and 24V 883s (and FIRST teams were supplied with 12V 883s, since FIRST has never used 24V systems). The difference between the 883 and the 884 had something to do with deadbands.
EDIT: Okay, I looked it up, and I was partially correct. The 883 can take between 6V and 30V, but the fan on top of the FIRST models could only take 12V. However, if you use two, you can wire the fans in series. The 884 has a greater dynamic range (3%-100% as opposed to 10% to 100%), and an added deadband to compensate. EDIT: Read SandDrag's comments below. I may have been looking at the wrong datasheet. Last edited by ahecht : 18-07-2005 at 17:11. |
Thank you so much. You just saved us about $300 on the cart.
hmm...it looks like we can even buy 24v fans from them from IFI for $8.95. i wonder if those would actually work with the 12v fan versions...
Yeah, those fans would work, and they are what we are buying. I guess the fans were the way FIRST used to try to make sure those things ran at 12V.
I'm not so sure. I wouldn't go hooking up 24V unless you get an answer from someone at IFI who knows exactly what you have and what it's specs are I remember there were two separate websites and possibly separate divisions of the company. There was IFI Robotics which served the combat robot community and there was Innovation FIRST which served FRC. I believe there were two different Victor 883s as well. This page seems to show that the FRC Victor 883s are not suitable for 24V use. this datasheet seems to confirm that. (Oh how wonderful the almighty Wayback Machine is) Additionally, these FRC Victor 883s are only rated for 30A continuous where the combat ones are rated for 60A continuous.
Now, it is possible that IFI/Innovation FIRST is lying and they are actually both the same 24V 60A model because they didn't want combat builders to get special pricing for FIRST so they tell us ours is 12V 30A, but I think it is more likely that they are indeed different units with different specifications. Note: the 24V Victor 883 can be seen here on the old IFIRobotics website and note that the 12V one linked to above is on the old InnovationFIRST website. So, Do not run your Victor 883s at 24V, at least not until we find out for sure. Also, Here's an alternative to 24V victors which is a bit cheaper (but it has no case or fan). It is two speed controls in one and can work on 4-36V and handle 50A continuous (per motor). Last edited by sanddrag : 18-07-2005 at 17:16. |
#7
I'd say try it, and if blows up... Oh well.
#8
Hmm, the info on the 30V stuff was from a spec sheet filed away with other documents I have from the 2002 season, but looking through the CD archives it seems that they were wrong (or perhaps for the wrong version of the 883). This thread seems to explain things a bit, while this thread leaves things somwhat in the air.
Incidently, Sanddrag, your first link goes to info on the 884, not the 883. This is probably the link you meant. Last edited by ahecht : 18-07-2005 at 17:07. |
#10
Would the 24 volt motor have acceptable power at 12 volts?
#11
| Brake/Coast setting for speed controller | cabbagekid2 | Control System | 0 | 16-02-2005 16:54 |
| speed controller max speed | Team 668 | Programming | 15 | 13-02-2005 14:05 |
| Speed controllers won't communicate w/robot controller | steven114 | Control System | 12 | 03-02-2005 21:26 |
| PID control loops - closed loop feedback | KenWittlief | Technical Discussion | 56 | 26-04-2004 21:27 |
| not quite sure...speed controller...spike. | tophq | Programming | 8 | 26-03-2004 13:43 |
