Go to Post Your iphone may be more intuitive for some of your students than a screw driver. - Isaac501 [more]
Unread 21-07-2005, 10:50
red_alert_13 red_alert_13 is offline
AKA: Patrick Frampton
no team (Red Alert)
red_alert_13 is an unknown quantity at this point
Assembly code in C?
I have a quick question: is it possible to use assembly code in C?
My experience was that in C++ (oh, how I miss C++), you could have code like this:
_asm
     /* Assembly code goes here */
I was wondering if the same thing would be possible with the compiler supplied by FIRST?
Thanks in advance!
Unread 21-07-2005, 11:54
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Assembly code in C?
This is called 'inline assembly' and is a nonstandard feature of most compilers, and they all seem to implement it in a slightly different way. Luckily, though, you don't have to look any further than the default code to find an example.
From ifi_startup.c:
void _startup (void)
  _asm
    /* Initialize the stack pointer */
    lfsr 1, _stack lfsr 2, _stack clrf TBLPTRU, 0 /* 1st silicon doesn't do this on POR */
    bcf  FPFLAGS,RND,0 /* Initialize rounding flag for floating point libs */
    /* initialize the flash memory access configuration. this is harmless */
    /* for non-flash devices, so we do it on all parts. */
    bsf 0xa6, 7, 0
    bcf 0xa6, 6, 0
  _endasm
loop:
    Clear_Memory();
  _do_cinit ();
  /* Call the user's main routine */
  main ();
  goto loop;
}                               /* end _startup() */
There's several other examples in that file as well.
Unread 21-07-2005, 13:23
no team (Red Alert)
Thanks for your response! That clears up a lot of questions.
Unread 21-07-2005, 15:01
no team (Red Alert)
Just in case anyone else might find assembly code useful, I found a link containing a list of commands - I'll have to test it but from the source code I've seen these are the commands used to program low level functions for the robot controller.
http://www.picbasic.co.uk/forum/showthread.php?t=222
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Code suddenly fails to initialize miketwalker Programming 11 19-02-2005 15:23
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
