pic: Robo-one legs
Re: pic: Robo-one legs
I must say that this is one of the coolest project I have seen around in this forum. But I do have questions for you...
In the picture you are using 11 servos... if you are adding a body with arm and a head, you would add atleast another 5 servos. How are you planning on powering 16 servos to work the same. What kind of controllers would you use and why? Do you think you will need more than one controller? what kind of battery are you going to use? Don't you think it will weigh a lot which may cause it to tip over? The legs look cool. Great job man. |
That looks pretty awesome. Nice job.
very nice!
Cool. I tried something like that once (but w/ Lego's, needless to say, it never really "worked", per say). Have you given it a test yet and will it have a gyro sensor to detect and compensate for balance? It really want to see this thing walk!
http://www.etek.chalmers.se/~almir/ this is also pretty cool and very similiar. i highly recomend the movie.
#7
We'll I've already tested it and it walks fine. I'm using a lynxmotion BASIC atom pro 24 pin module and their mini Atom bot board. I'm going to have to purchase their servo controller though because I need to control (ready for this) 19 servos. I didn't really design it to walk up stairs but it can. And I'm not using any gyros (yet), it just takes about 400,000,000,000,000,000 tries before I get the servo placements and timings right so it doesn't fall over. I plan on putting up a video of it walking, but first I have to program it. If you plan on building something like this DON"T but the BASIC atom pro + bot board, it can control 20 servos, but only 1 at a time. So lets say i want the legs to crouch and both motors need to move an equivalent of lets say 800, I have to divide it by a big number and then move each one back and forth.
IE. SERVO 1, 5 SERVO 2, 5 SERVO 1, 5 SERVO 2, 5 etc. O, and for the batteries, I'm just using a 9 volt battery because the BASIC atom board can take up to 9 volts and convert it to 5 volts for the micro controller and the servos. Last edited by [527]phil : 27-07-2005 at 09:37. |
#9
Ive seen videos of these kinda robots they are really impressive to watch move.
#10
yeah i was specifically impressed with the logic programming on that robot.
#11
I'm having trouble with the programming though, if anyone knows how to put voltage through a pin in order to keep a servo from moving, or if you know how to make more than one servo move at a tine, OR if you know how to sue the pulsout command, please help!!
| Programming a 2nd PIC | ImmortalAres | Programming | 8 | 16-06-2005 12:13 |
| Learning PIC C | Adam Collet | Programming | 18 | 19-10-2003 19:36 |
| PIC Programmers | seanwitte | Electrical | 8 | 18-04-2003 17:04 |
| pic: Team 522 Robo Wizards Mckee H.S. Staten Island N.Y. | CD47-Bot | Robot Showcase | 18 | 17-04-2003 20:40 |
