Go to Post This thread is making me all vaklempt. :) This is FIRST at its best! Advice, offers for spare parts, and even lunch! You all ROCK! :D - Cynette [more]
Unread 30-07-2005, 00:10
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Old School machining question
This question is directed to the machinists... back when CNC wasn't so big.
Why can Volstro rotary mill heads only cut in a counterclockwise direction? The one I have been using cuts perfect counterclockwise, and cuts terribly clockwise, and not because of climb/conventional cutting differences. There is even an arrow to tell you that, but you can still cut clockwise. How come?
Unread 30-07-2005, 00:16
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Re: Old School machining question
i wonder if it has to do with either the motor or the drive train. im not fmiliar with the system so i cant talk in depth on it without being more familiar. ill look it up on google.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 30-07-2005, 00:44
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Maybe it has something to do with the way the belts are set up?
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 30-07-2005, 14:37
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
no it couldn't really be the belts, unless they have rather unique grooves. Take for example, last year's CIM motor, ever run it in reverse? If you did you'd notice there was a rather large change in RPMs. This is caused by the motor brushes most the time. What happens is that the brushes are pushed into an offset position and peak performance doesn't occur when the current is simply reversed.
My one solution to improve performance besides getting a new motor, is to possibly add another gear somewhere to reverse the direction of the spin with out changing the current input into the motor.
------edit------
I guess I kind of worded it wrong earlier, to make my point a little clearer:
1.) Nothing is wrong with the Mill at all, its the motor
2.) The problem with motor is quite simple, first I'd reconmend reading this to understand how a motor works, or you'd probably have no clue what i'm talking about.
3.) What is happening is that the brush is being pushed offset by the direction of the current and by being pushed offset its no long running at the optimised speed. Read this for a more detailed explaination.
Unread 30-07-2005, 15:44
AKA: Bradley Rigdon
I know about the motor speed problems.
I was just thinking that the belts may have some sort of tensioner that might create a shake or bouncing effect in the spindle when run in the opposite direction.
Unread 30-07-2005, 16:41
This has nothing to do with the mill itself, the mill works fine in both directions. The rotary mill head is something you put on the spindle itself, by clamping it to the quill. It has a standard R8 taper to recieve power from the mill, and it has two levers, cutter offset distance and rotation. This tool is a different approach to rotary table work.
Unread 30-07-2005, 18:53
Ive been following this thread because i myself have wondered about it. now it kind of makes sense.
Unread 31-07-2005, 11:52
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Well I read Through this post now twice and I am seeing what you are talking about. I haven't been in machining for that long as some of you here but it seems to me that there might be nothing to do with the mill or the head it might be the cutter you are using. Most cutters will cut horribly back wards not sure if this is the problem but it seems to be it might be worth checking out. Very interested in hearing the solution to this problem keep us posted please.
Drew
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 31-07-2005, 14:39
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
First of all, it seems that some people are wondering what this thing is; here are a few pictures, as well as the opportunity to buy one, if you're so inclined.*
Now, I don't personally have experience with this thing, but is it possible that some components inside are axially loaded, and that loading is dependent on the direction of rotation? (For example, helical gearing transmits an axial load to the shaft, and its direction depends on the direction of rotation of the driving gear.) That axial load could conceivably cause the behaviour described (by forcing the cutter into the workpiece in one direction, and upward into a thrust bearing in the other direction).
*I have no relation to the seller!
Unread 31-07-2005, 21:03
Thats exactly the one I'm using. I was using a brand new .250" end mill on it as well. Sadly the company has gone out of buisness, but it is useful anyway. As long as you rotate the head the right way.
Indiana FIRST 2005 line up Kyle Love Regional Competitions 4 04-11-2004 00:04
What does the Chairman’s Award have to do with a robot contest? Ed Sparks Chairman's Award 32 15-02-2004 13:39
What do you feel about the growth of FIRST? Ken Leung General Forum 35 03-05-2003 23:06
How to keep a program running at a school which doesn't get it? Jimmy General Forum 9 03-04-2003 10:08
KSC awards archiver 1999 4 23-06-2002 21:59
