Go to Post That is the ultimate "dream match" that I long to see. If not during the season, maybe we will see it at IRI. :) . - dlavery [more]
Unread 02-08-2005, 22:49
Andrew Blair's Avatar
FRC #0306 (CRT)
Power signal Connectors?
I am considering designing a modular electronics box in which components ( spikes, victors) are mounted to a piece of lexan, and all wires, voltage input, motor output, pwm, are all on one connector at the edge of the board, like a stick of RAM. I am currently considering these, Crown Edge Connectors , as they can carry both power and signal in one easy package, but I imagine they will be absolutely outrageous. Does anyone know of good connectors like I'm talking about?
-Sir Francis Bacon
-Albert Einstein
Unread 02-08-2005, 23:31
BrianBSL BrianBSL is offline
FRC #0190
BrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud ofBrianBSL has much to be proud of
Re: Power signal Connectors?
You could try using Anderson Powerpoles - they link togeather. www.powerwerx.com sells some. You would have to make a custom bracket to mount them, however, and using them for signal would end up with some huge connectors. You are probally best off with a seperate signal and power connector.
Unread 02-08-2005, 23:33
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
make your own connector if need be, how thick is the lexan if more then like 1/8" put it on a mill and take the edge down
take a piece of the copper clad circuit board and etch a small strip and put it on the edge of the lexan with screws then for the female end make a simple 5 sided boxbut on the side opposite the opening take an end mil and mill out a like edge that is alternating for strips of copper that can be put theour and have a hole drilled in the outside edge so wire can be soldered to it or to a circuit board na dten just bend the copper in side the female end so they act like springs with constant contact
if that doesnt suit you then get something like the power connector for power supplies in computers, i believe they have 20-24 connections i dont remember exactly how many
Unread 02-08-2005, 23:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I would strongly recommend that you do not make your own connector. As previously mentioned, Anderson PowerPoles are good, but you will have to come up with a mounting method. www.robotmarketplace.com sells them too.
Unread 03-08-2005, 12:49
FRC #0306 (CRT)
Thanks guys, but if possible I would like to have it all in one nice little unit to simplify things. Actually, could you safely hack a serial cable and put our 12 volts dc through it?
-Sir Francis Bacon
-Albert Einstein
Unread 03-08-2005, 13:02
FRC #0190
For running power to spikes, etc? No way, the conductors are not large enough to handle that much current for any length, plus it would not be FIRST legal. The insulation is surely rated for 12V DC, but the current is what is important.
You could easily have 2 harnesses, one for pwm signal, and another for power i/o. You are not going to find anything reasonably priced that has 20 or so 40A contacts and another 20 signal contacts, epically not on an edge connector. And, I too would avoid making your own connector, for various reasons, but most importantly safety.
Unread 03-08-2005, 13:43
I might suggest a hybrid connection where all the high current connections are made through PowerPoles which can be keyed for foolproof mating and a smaller connector for controls. Check Digikey and you will find that manufacturers like Molex make mounting hardware for their connectors as does PowerPole. I have seen (and inspected) teams using this configuration that were legal under FIRST rules. One caveat is that the assembly is now part of the electrical connection. If you do not have some way of holding the electrical connectors together they will become intermittent during competition.
Unread 03-08-2005, 13:59
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Im also looking at making a electrical box. Im only planning part placement right now but ive started looking at connectors and considered two ideas. One would be the power poles, and the other is using a wire harness but im not sure about the legality of doing this. On a side note im wondering if anyone knows which serial pin provides +5 volt power to the transmitter/reciever?
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 03-08-2005, 14:30
Hutch Hutch is offline
NOTAG
Hutch will become famous soon enoughHutch will become famous soon enough
For all of your pinout needs, http://pinouts.ru/
More specifically though, http://pinouts.ru/pin_SerialPorts.shtml
Unread 03-08-2005, 14:54
I've been there and im not sure which cable we use and many of those diagrams say the power is a different pin.
Unread 03-08-2005, 16:22
NOTAG
Yeah, I guess sometimes pinouts.ru is a bit much... Anyhow, according to http://www.aggsoft.com/rs232-pinout-...and-signal.htm there is no power output, just a shared ground. Anyhow, you could always put a voltmeter to it.
Unread 03-08-2005, 16:36
FRC #0190
Isn't the radio RS-485 or one of those 4xx ones? I could be wrong tho.
Unread 03-08-2005, 21:48
FRC #0306 (CRT)
Well, actually, I was considering only putting one spike or victor on one lexan piece/electrical connect. So I will only need 4 forty amp connectors and 3 signal connectors. I don't know if this makes anything more available.
-Sir Francis Bacon
-Albert Einstein
Unread 03-08-2005, 22:14
FRC #0190
You could just use 3 pins of a .100 in header and 4 powerpoles for that, held in place by some type of custom bracket. Using the .100 in header would allow you an "emergency mode" of plugging in a regular pwm cable, as well (its the same type of connector that is on the RC).
PWM Style .100 pitch Male Connectors BrianBSL Electrical 2 05-10-2004 19:43
RJ-45 connectors, DB25 connectors and the like: legal or no? Andrew Wyatt Technical Discussion 6 04-01-2002 22:53
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
