Go to Post "As president, I believe that robotics can inspire young people to pursue science and engineering. And I also want to keep an eye on those robots in case they try anything." — Barack Obama - Ted Weisse [more]
Unread 02-09-2005, 09:46
REVving up for a new season
FRC #2848 (All-sparks)
looking for 1 joystick Pbasic drive code
for my battle bot i am using one of the older pbasic controllers w/ 1 joystick. We have tried for some time to play with the default 1 stick code but we can;t get it to work. So i figured i would ask and see if anyone has any successful code.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 02-09-2005, 09:55
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: looking for 1 joystick Pbasic drive code
Could you post some code?
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 02-09-2005, 11:01
Here's the 1-joystick code we used for driver practice this year on a second robot using one of the older controllers. I don't remember if it's any different than the original default code other than minor changes though. It does a debug printout of the drive values being sent to the PWMs.
The right drive motors are on PWMs 1 & 2 & 13 & 14
The left motors are on PWMs 3 & 4 & 15 & 16
P.S. This second version was used on a third robot, but reverses the behavior of the joysticks due to motor wiring and mounting. It switches between 1 and 2-joystick operation based on the value of p4_sw_aux1 where we attached a switch on the OI.
Unread 02-09-2005, 12:25
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
greg this is what i used on my robot, just pick the code you need
http://www.ifirobotics.com/first-legacy.shtml
the "default" codes are for 2 joysticks and the "user" codes are for 1 joystick
Unread 02-09-2005, 14:47
that is the code we can;t get working....it says to put your Pwm in ports 11-12 and when you do the motor are just full on....I tried calibrating the speed controllers with no luck.
I was kinda hoping someone would have some custom code that was driven during the season during those years. Something that has been throughly tested and known to work well. IFI default codes sometimes work in theory but not in real life.
Unread 02-09-2005, 15:00
Read it again. The 2003 default code for 1-joystick drive that I'm looking at puts the right side outputs on pwms 13 and/or 14, and the left side on pwms 15 and/or 16. Pwms 11 and 12 are set from the p3 and p4 wheel inputs, respectively.
Unread 02-09-2005, 15:59
Be sure to remove your custom calibration after moving to the correct PWMs or else it still won't work.
Unread 02-09-2005, 20:35
i mistyped the port numbers we were trying the correct ones.
We fixed it by trying a different controller....there was an internal problem with my joystick (but i guess that is what I get for 6 bux at goodwill )
Unread 02-09-2005, 17:24
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
i am using the default code on my robot, infact i was just playing with it not too long ago today and i didtn have any problems, I never even read the directions, i just pluged the pwm cables into pwm 1 and 2 and the joysticks into 1 and 2 and it works perfectly
did you try adjusting the trim pot on your joystick?
Change joystick to pwm mapping Joe Lewis Programming 3 30-03-2005 19:27
Drive Straight C Code using Encoders without PID? Chris_Elston Programming 17 15-02-2005 23:41
trentonDrive.c: our joystick/wheel drive code gnormhurst Programming 16 03-02-2005 14:40
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
TechnoKats Automated Test Drive Code Greg McCoy Programming 1 16-01-2003 17:45
