Go to Post The spirit of the game, and the game are essentially two different things. - ttldomination [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 11-10-2005, 18:54
troy_573 troy_573 is offline
Team 573 (No Place Like Home)
AKA: Troy
FRC #0573 (The Mech Warriors)
troy_573 is an unknown quantity at this point
Send a message via AIM to troy_573
[OCCRA]: Potientiometer
Help! In FIRST we connect our 10-turn pots to nylon sproket and hold the sproket into the chain. I have figured out how place the pot. in the correct location but i cannot figure out how to attach the 3/8" shaft to the approxamite 1/4" shaft of the pot. any suggestions ... is it against the rules for me to ask these kinds of questions?
Unread 11-10-2005, 20:29
occra 23.
AKA: ryo
None #1481
Re: [OCCRA]: Potientiometer
i dunno.... i havent seen our pots ina LOOONG time. maybe never. we've obviously never used them. so. waht exactly do they look like? i dont thave the handbook handy right now.
Unread 11-10-2005, 21:12
AKA: Troy
Its this little blue thing with a small shaft sticking out of it, looks just like a rotary encoder ... i can make the question so you dont have to under stand how a pot. works .... we preety much need to attach a 1/4"(?) shaft to a 3/8" shaft
Unread 11-10-2005, 21:48
occra 23.
AKA: ryo
None #1481
ahh... um how much torque is gonna be on these? at worst ducttape them together.. or get a bushing on the 1/4 shaft with a OD of 3/8 and then get another bushing of inner diameter of 3/8 and go over both the 3/8 shaft and the 3/8 bushing which is over the 1/4 shaft and then drill a hole through both ends and tap a pin through them
Unread 11-10-2005, 22:09
AKA: Dr. Brooks
no team (WRRF)
Use a flexible shaft coupler. For an example of one that adapts a
1/4 inch shaft to a 3/8 inch shaft, see the web page at:
http://www.surplussales.com/ShaftHar...ShaftH-10.html
These couplers are available from many sources.
You can also use a coupler that is not flexible, but then you need to
make the mounting for the pot flex a little to avoid problems with binding.
Unread 12-10-2005, 21:44
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Please remember to look at the additional materials list and see if what you want to use fits the items listed. We would not like to upset you by having you take off parts that are not legal. Please review the list.
BTW. What are you going to do with the pot? Unless you are programming it is useless. Now a limit switch-----thats easy to use.
Mike Martus
Unread 14-10-2005, 12:29
AKA: Troy
We are going to automate our arm Chris Barch has already writen the code (twice) so that we can push a button an our arm will automaticly go to a location. Our team does this in FISRT and we going to do it in occra to but its harder to do in occra because we can make our own switches to program our preset positions.
[OCCRA]: [OCCRA]: Motor Question JoeFryman OCCRA Q&A 1 21-09-2005 21:25
[OCCRA]: [OCCRA]: Material Donations xzvrw2 OCCRA 2 17-09-2005 08:55
[OCCRA]: [OCCRA]: Robot spending limit? Eric Yahrmatter OCCRA Q&A 1 13-09-2005 20:31
[OCCRA]: [OCCRA] drill transmission greencactus3 OCCRA Q&A 1 11-10-2004 19:31
[OCCRA]: [OCCRA] LEDs greencactus3 OCCRA Q&A 1 11-10-2004 19:30
