Go to Post Now that the robot is shipped, maybe I can get to bed before the alarm clock goes off =] - DarMagi [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 24-10-2005, 19:23
bighpfreak bighpfreak is offline
bighpfreak is an unknown quantity at this point
Egg drop Contest- Help Please!!
I know. Another egg drop contest. But I would really appreciate any help anyone could give me. Thank you in advance.
First off, I have material restrictions. I can not use any sponges (or sponge like material), manufactured boxes, manufactured stuffed animals/toys, styrofoam and foam padding.
I also have a size and weight restriction. The object cannot be bigger than 35cm x 35cm x 35cm. If the vehicle has a parachute, the parachute must fit within these restrictions. And it can not weigh more than 350 grams.
And lastly, the contraption must hold TWO eggs, and must be able to withstand numberous drops (i.e. it will be dropped from 1 m, 1.5m, 2.5m, 4m, and from the roof of my school. Between each drop height I am not able to fix or repair anything on my contraption. The vehicle might also be thrown across the room, or flipped upside down, while falling).
Now, does anyone have ANY ideas at all?
Thanks,
Cassandra
Unread 24-10-2005, 19:28
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Egg drop Contest- Help Please!!
http://www.chiefdelphi.com/forums/sh...light=egg+drop
This page is fantasic!
Unread 24-10-2005, 19:34
occra 23.
AKA: ryo
None #1481
well i found the long skinny balloons you use to make party animals work as sweet cushioning. i did it with air. try with helium.
Unread 24-10-2005, 19:58
Thanks for your help, both of you.
I check out those links, but most of the other projects are just for 1 egg, and have different material restrictions and whatnot than me. Like for example, I can't exactly use the cone idea, as it will just crumble after the first drop.
Thanks for the idea about the balloons. I will be sure to try that.
Unread 24-10-2005, 20:09
Well, I thought there were enough discussions on this already, but apparantly your project is different enough to warrant another one.
I'm kind of thinking if you could somehow suspend them in the middle of something like a small beach ball. But I don't know how to open a beachball and still close it where it still holds air.
Does the parachute have to fit within the size restrictions even when it is deployed or only when it is stowed?
Unread 24-10-2005, 20:13
occra 23.
AKA: ryo
None #1481
are you kidding? have you never heard of the miracle which is called duct tape?
Unread 24-10-2005, 20:20
It must fit within the restrictions when it is fully extended.
I've attempted to build one already - consisting of popsicle sticks, elastic bands, and these cup holder things. Only problem is, was that it was way too heavy for the parachute to have any sort of affect on the contraption.
Thanks for all of your help already
Unread 24-10-2005, 20:25
Ive heard that the best padding material for this is lawn clippings - grass from your back yard.
maybe thats why some many species of birds make their nests out of grass?
Unread 24-10-2005, 20:40
Beth Sweet's Avatar
Beth Sweet Beth Sweet is offline
is getting lost in her new home
FRC #0116 (Epsilon Delta), #1504 (alum), #67 (alum)
Beth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond reputeBeth Sweet has a reputation beyond repute
I know that in my class people used a tin can full of jello, but that was for one egg, maybe something along the same lines filled with jello?
This season, I was a part of a great team, with great kids who were really inspired, and who inspired me back. That's my brag, what's yours?
Unread 24-10-2005, 20:50
I was thinking something along those lines too, but the only problem there is weight.
Best Available Data
FRC #1778 (Chill Out!)
EDIT: Uh, how much does 350 grams weight in ounzes and pounds for those of us who are metrically challenged?
Thank you Ken! I'm not sure what it means by manufactured box but if you can use a cardboard box for example, or any container, (probably the bigger the better) fill it to the brim with grass clippings (assuming they are still available where you live). Then put the two eggs as close to the center as you can, without them being two close to one another. Have Fun!
Unread 24-10-2005, 21:02
occra 23.
AKA: ryo
None #1481
-edit- whoops. 16oz in a lb not 12.
obviously im a metric person
Unread 24-10-2005, 21:07
Originally Posted by greencactus3
350grams*12oz/454grams=9.25ounces.
i htink i did my factor labeling right.....
Nope, there are 16 ounces in a pound, not 12.
(350gr/454grperlb)(16ozperlb) = 12.33 oz
Unread 24-10-2005, 21:11
unless you are measuring precious metals, then its 12 oz to a pound (which is why a pound of feathers weighs more than a pound of gold)
isnt the SI system wonderfull?
What my teacher means by "manufactured boxes" is that you can't use an already made box. You can make a box, out of whatever you'd like, but it can not be a box that you buy in stores or whatever.
Thanks again.
What does everyone think about a pyramid shaped thing?
please help me! its an egg drop contest jess Math and Science 13 09-09-2005 21:20
CD's Unofficial Caption Contest #53 Billfred Games/Trivia 34 17-07-2005 16:53
The Egg Drop Project Joe Matt Math and Science 1 20-05-2005 13:05
nother egg drop contest SchmitTheNordic Math and Science 11 30-04-2004 23:25
Egg Drop Contest Matt_Kaplan1902 Math and Science 27 02-02-2004 14:45
