Go to Post Does that mean that the Ultimate Question of Life, the Universe, and Everything is, "How many total tubes will be available to score for the FRC 2011 game, LogoMotion? - EricH [more]
Unread 01-11-2005, 16:32
occra 23.
AKA: ryo
None #1481
drilling into sprockets
we have these HEAVY sprockets we would like to drill holes into to lose weight. they are the black ones. im assuming hardened steel. we've tried carbide bits, cobalt bits, and regular bits and each one burns up with one hole or less. we have been applying oil generously but they still die on us. what are we doing wrong? we drilled lots of holes in the same sprocket with one bit with no problems before. and we barely had to use oil then.. we arent sure which bit we used back then but we know it was a 1/2 in bit. same as what we are using now. why can we not drill a 1/2 in hole into our sprockets without killing them? or we know we can take off the hubs. can a bandsaw cut them off? (we are not allowed to use a lathe... this is for OCCRA. which lathes are not allowed.)
well, any other way we can drop weight from these sprockets? (we are not allowed to use smaller sprockets/chains.)
Unread 01-11-2005, 16:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: drilling into sprockets
are they Martin sprockets? if so they shouldn't be hardened, or maybe only surface hardened. Some sharp regular HSS or TiN coated bits should go through them just fine with a good amount of oil (making lots of smoke in the process). Are you using a hand drill or a drill press? What rpm? Use a d illpress if you can. From what you describe, try using more oil (most anything works, even motor oil) , a much slower speed, and a slightly heavier feed. I've drilled through many sprockets in my time and the black carbon steel ones never gave me any problems.
Unread 01-11-2005, 17:28
occra 23.
AKA: ryo
None #1481
i actually have no idea what brand they are. but they are harder than regular steel. our carbide and cobalt bits were brand new. so they hsould've been nice and sharp. and we are using a drill press. i dont remember what rpm but we tried a variety of speeds. and we were using motor oil. and we were basically drenching the bit/sprocket continuously while drilling. and we are supposed to go slower rpms? thats what i thought but the guy someone talked to from the hardware store said spin it as fast as you can. darn. knew that meant more friction...
Unread 01-11-2005, 17:38
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
harder the material=slower the rpms
harder the material=TONS OF MACHINE OIL/LUBE (NOT MOTOR OIL)
the more oil=better cut=longer tool life
regardless to the amount of smoke that you make, the smoke should be minimal with proper rpms....if you hog into the peice and your oil instantly burns up, turn the rpms down and add more oil....
One more thing, is drill smaller holes into hard material first...that means less for the big drill to remove (big drills have less of a angle that enters the material first, thus making it much harder to get in.)
hope this helps
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 01-11-2005, 17:51
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
First of all, if you used to drill these without issue, and now there's more effort required, maybe your drill press spindle is wobbling a bit? Or maybe the workpiece isn't secured quite right?
If that's not the case, try centredrilling, then starting with a smaller bit (3/16" or something), and going up in increments.
If you want to get rid of the hub, grind it off with a surface grinder (if the rules permit it). If the hub is welded on, cut the welds off with an angle grinder, then try to split it with a chisel.
Unread 01-11-2005, 19:11
Andrew Blair's Avatar
FRC #0306 (CRT)
Mmmm, I hate to even bring this up, but are you drilling in the correct direction for your bits? I know occasionally you'll accidently pick up a left handed bit, or not check the direction. We burned up a hole saw two years ago, and I've broken a couple bits myself in this way.
-Sir Francis Bacon
-Albert Einstein
Unread 01-11-2005, 19:12
Umm Errr...
I'm no machining expert, but my guess would be that you are using a spindle speed that is way too high. As a general rule, use faster spindle speeds for aluminum and VERY slow ones for metals like steel. In addition, the bigger the bit you are using the slower the speed should be. Also, it might be a good idea to work your way up to 1/2" rather than tackling it in one step.
1139 Alumni
Unread 01-11-2005, 19:47
occra 23.
AKA: ryo
None #1481
thanks everyone. yea. thats what i thought..... $@#$@#$@#$@# hardware-store-guy-that acts-like-he-knows-but-doesnt-really... ill try spinning it slower. and yes these are right handed drill bits. only lefthanded ones ive ever seen are tiny screw removing ones. and well.. thanks again. ill let you guys know if nothing works.. and then we can wonder how our steel sprocket turned to diamond overnight lol.
Unread 01-11-2005, 22:07
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
I'll second that, I remember drilling through the large kit sprockets (2004 KoP I think). It wasn't extremely difficult once you got the drill through the surface layer.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 01-11-2005, 22:46
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
What ever you do, just make sure this does not happen in the process.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 01-11-2005, 23:10
Umm Errr...
How did you manage that? Metal can break in funny ways. I remember one year a piece(made of extremely hardened steel) falling off the table and shattering into two very sharp pieces.
1139 Alumni
Unread 01-11-2005, 23:18
AKA: Bradley Rigdon
I'm not exactly sure, but the metal the sprocket was made out of was junk.
I think the bit may have caught on a burr and from there it just shattered in half. It could have also been that it was clamped in the vice to hard.
This was in 2004, I was in the shop at the time, but I wasn't machining it.
Unread 01-11-2005, 23:38
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
I'm not exactly sure....... It could have also been that it was clamped in the vice to hard.
I think you answered the question quite well. I photoshop'd the image as best I could. Looks like it must have been clamped in the vice by the hub, compressing across the central axis. Even if the sprocket didn't break, you might have had one incredibly rough time putting it on a shaft.
Suggestion; next time, put it in compression along it's central axis. That way, you won't risk deforming the hub, and, much less chance of it breaking.
Unread 02-11-2005, 10:21
evelyn1503's Avatar
evelyn1503 evelyn1503 is offline
AKA: supper sister fix-it
AKA: evelyn palleschi
FRC #1503 (Spartonics)
evelyn1503 is on a distinguished road
I think I know the sprockets that you are talking about and they are a pain to drill. I think what we have done is the t we have 2or 3 drill bits and when one wore down then we grabbed another and so on... then you have some one sharpening the dull one it sounds like a pain but I found that it was a good way to do it the you have a sharp drill bit.
Evelyn Palleschi
2005 Pit Captain
2005 Waterloo Regonal--Semifinalist
2005 Grater Toronto Regonal-- Finalist
2005 World Finals(Atlanta- Curie)--Quarterfinalist
2005 Canada's Wonderland( Off Season)--Champions
Cheering takes spirit, spirit sparks dreams, dreams become possibilities, possibilities become realities....NEVER STOP CHEERING
Unread 02-11-2005, 12:13
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
If you are trying to lose the weight of an attached hub, get a portable bandsaw or borrow one from a plumber type, they use them for cutting metal pipe in the field, Milwakee makes a great one. Use the portable band saw to hack most of the hub off. We did this in 2003, with a bunch of donated gears and sprockets and saved several pounds of weight. Last year we tried to use a lathe to turned down a sprocket hub and it sucked, found out later that the spocket has Stainless which is more difficult to machine. My advice is to use a portable band saw.
[OCCRA]: Rule Clarification- Motors and Sprockets Alex Golec OCCRA Q&A 1 20-09-2005 19:37
Drive Assembly Sprockets are Custom Bored Mark Pettit Kit & Additional Hardware 35 09-03-2005 19:05
8" wheelchair hubs and 25 tooth sprockets Kirk Stankiewcz Kit & Additional Hardware 9 14-12-2004 19:54
[OCCRA]: the motor sprockets greencactus3 OCCRA Q&A 1 22-09-2004 20:11
sprockets from mscdirect Max Lobovsky Kit & Additional Hardware 5 29-01-2004 23:59
