Go to Post It does it automagically. - David Kelly [more]
Unread 06-11-2005, 00:07
White_Orpheus's Avatar
White_Orpheus White_Orpheus is offline
Woot for Aphex Twin!
AKA: Chris Teresi
FRC #0253 (MRT)
Team Role: Animator
White_Orpheus will become famous soon enoughWhite_Orpheus will become famous soon enough
Send a message via AIM to White_Orpheus
Material help
Well, that 350Z got ruined far beyond repair when i started putting in doors, so I'm working on an A3 right now. I'm trying to get a color like This , but i'm having a really hard time. Any suggestions on a material for the paint coat?
Additionally, I have no idea how to get a reflective material like that grille outline. Every time i get a silver reflective material, it just reflects the render background like crazy and ends up looking like nothing. Any help would be appreciated!
Team 253
2004 Silicon Valley AVA Winner
Unread 09-11-2005, 11:02
Baden3DMAX13's Avatar
Baden3DMAX13 Baden3DMAX13 is offline
IUPUI Student/ 3D Animator
None #0393 (Full Metal Jackets)
Baden3DMAX13 is on a distinguished road
Send a message via AIM to Baden3DMAX13 Send a message via MSN to Baden3DMAX13 Send a message via Yahoo to Baden3DMAX13
Re: Material help
Ok, first off, shame on you for not saving multiple copies of your 350z before continuing on hard stuff like doors, windows, grills, ect. That was coming along nicely(another helpful trick that you can do in the future to prevent you alot of heartache is to use the new Edit Poly Modifier in 3d studio to give you some flexability. The reason for this is, the new modifier lets you stack them and make changes on each one, if you go back down the list to the previous edit poly you were working on, it will show you the changes that you made on that edit poly and the ones before it. That's just incase you didn't know that helpful trick.) Ok, anyway, to the material, first off go here and follow this tutorial exactly. It will give you an amazing base material. After you're done with this, you can edit it to your own wants/needs. You can change the color/what not. Also, you can change the specular from none to noise or cellular(when you do this change the size value from 25 or whatever the default is, to something small, like .25, this will give you the illusion of flakes in the paint.) Anyway, from there, you just go on and do what you want to do with it, if you want to see what it looks like, check out my Fiat 500. Ok, and now for the grill material. The grill material I'll have to get back to you on that one, I know that the metal material on my bumper and rims looks pretty sweet, but I don't have it in front of me to tell you how I did it, I know that I used HDR in it's creation. But for now, that's what I've got for you. I hope that this all helped at least a little.
Out of all the things I've lost, I miss my mind the most. - Ozzy Osbourne baby!!!
Fiat 500 (WIP) <~~Check It Out!!!!
Unread 09-11-2005, 23:01
AKA: Chris Teresi
FRC #0253 (MRT)
Team Role: Animator
Re: Material help
I was thinking about the Z, spent a couple hours, and managed to remove all the damage i did to it. I started putting in doors and windows, but something looks a little weird with the windshield. Nothing some tweaking won't fix though. Anyway, thanks a lot for the material help.
Team 253
Unread 10-11-2005, 11:08
Re: Material help
Hey man, anytime you need help, just ask. I'm more than happy to help out a fellow 3d artist. Btw, what did you think of the Fiat??? I haven't really got any crits on it.
Unread 10-11-2005, 11:30
Re: Material help
Oh, hey, I just remembered about the metal grill thingy... ok, I used a shellac material with a color mix of 23. The base material is an architectural material, here's a pic~> Architectural. The HDR file that I used was a custom HDR that I made, you can substitute any HDR that looks good in it, and mess with the light/dark areas on it, next the shellac material. I used another shellac for it with a color mix of 12, and it get complex from here.... here's the setup for the base of the next shellac material ~> base2. The material map that I used for the reflect was just the HDR. Now for the final shellac.. here's the setup ~> last but not least. And there you have it... It may take some doing to make (not really, there are harder) but in the end, the product looks pretty cool. Anyways, I hope that this helps you, if you have any questions, just ask.
Unread 10-11-2005, 19:39
AKA: Chris Teresi
FRC #0253 (MRT)
Team Role: Animator
Re: Material help
I think increasing the final gather count might fix up some of those oddities on your Fiat render. Also, it looks like you have a little dimple in the roof of the car on the last render. I'm not sure if that's just how the car is, or if it's an error. My final nitpick is that older tires like the ones on the fiat should have white sidewalls. Other than that, it's looking great!
Team 253
Unread 11-11-2005, 18:10
Capt.ArD Capt.ArD is offline
Animator
FRC #0116 (Epsilon Delta)
Team Role: Animator
Capt.ArD will become famous soon enoughCapt.ArD will become famous soon enough
Re: Material help
For the car paint, that tut is pretty good, but I had an idea for you.
When you make the paint, make it have a falloff map as the initial diffuse, then your bluish color and a slightly lighter color ( in this case, a little lighter blue with a VERY small amount of green) as the two sub-colors. This gives the paint a sort of highlight. The light part shows up on the edges, and shifts with the light. It really brings out the detail and adds more dynamicy to the animated model.
I'm sure you already knew about falloff, but i wanted to reccommend it. I always use it for the shinies and the pretties in my models.
Unread 14-11-2005, 14:12
Re: Material help
Hey man, thanx for the input, I'll do the whole white tire thing, and I'll try bumping up the final gather amount. Hopefully that fixes some of my problems. Thanx.
Another thing, the falloff that he's talking about does give it a pretty cool look. You can even use that to do kind of a pearlescent paint job.
Unread 17-11-2005, 09:45
Re: Material help
Hey! Here's those tires you wanted also, I bumped up the samples on the Final Gather, but still got some spots, i went from 1000-7500. I didn't just jump, I tried other stuff out, but I still have no idea why it keeps on doing that... weird... Oh well, here's the tires
Unread 17-11-2005, 19:56
AKA: Chris Teresi
FRC #0253 (MRT)
Team Role: Animator
Re: Material help
What material are you using for the headlight lenses? Maybe something weird is happening with refraction or something like that. I would try rendering it with the lenses hidden and then seeing if it cleans up.
Team 253
Unread 21-11-2005, 10:58
Re: Material help
It's just a raytrace material, I'll try that.. I've messed with it alot, and I'm just baffled. But hey.. whatever. Thanx for the input.
Seeking Thermally Conductive Material Torchin Chit-Chat 0 25-01-2005 05:59
**FIRST EMAIL**/Advance Material List for the 2005 Competition Now Available! Travis Hoffman FIRST E-Mail Blast Archive 0 05-01-2005 16:46
Cheezy Poofs' Wheel Material evolution Technical Discussion 6 18-04-2004 23:11
Illegal material PDonovan Rules/Strategy 13 16-05-2002 16:53
Best material for wheels. Dr.Bot Technical Discussion 0 21-01-2002 23:32
